Old 02-11-2024, 11:31 AM
K Roche's Avatar
K Roche K Roche is offline
Default Inner Circle new Handy Drums plug in solved
So I got the new InnerCircle free Handy Drums plugin
And everything works and sounds fine EXCEPT using multiple outputs does not work
I followed the Gorgan Grooves tutorial for multi outputs in Pro Tools
#1 Put the plugin on a stereo instrument track (which will play all the different drums correctly)
#2 made more stereo (tired mono also ) instrument tracks (for Kick -Snare - Toms -HH- ect.)
#3 chose different plug in mixer channel outs for the different drums i.e. Kick 3-4 ,, Snare 5-6
#4 chose the corresponding input on the PT instrument tracks i.e. channels 3-4 for Kick track etc. etc.
the Handy Drum mixer output selection shows all the channels listed like st1 -st2-st3-st4 etc. BUT the only miser channels that will pass a signal are st1 and st 2
Any body get this plug in to work correctly ?
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1
Enjoy the Journey
.... Kev...
Old 02-12-2024, 07:12 PM
Halfmoon Halfmoon is offline
Default Re: Inner Circle new Handy Drums plug in does not work correctly
I haven't worked w/ Handy Drums but assuming it's similar to other multi-out-capable plug-ins, I think your step 2 might be causing the problem.
I've never used Instrument tracks to receive the audio output from a multi-out plug-in (I use audio tracks instead...or I guess you could use Auxes).
Try that and see if it does what you want it to be doing.
I hope this helps.
Old 02-12-2024, 08:08 PM
take77 take77 is online now
Working here on my Windows 10 system.
Created 1 stereo instrument track + 9 more stereo instrument tracks (I prefer inst tracks so the the newly created channels aren't solo safe by default).
I set up the output config on the plug-in first then used the Windows shortcut for auto-assigning the outputs to respective inputs (Ctrl + Shift + Alt) when selecting "plug-in>3-4" in the I/O input drop down menu (from the first of the 9 newly created instrument tracks).
Maybe the plug-in reverted to the default config somehow. Try keeping the kick on 1 & 2 since that output is assigned to the original instrument track.
** I think the shortcut for Mac is Command + Shift + Opt
I'm going to try this with Toontrack EZplayer which serves as a host to all my MIDI libraries.
Ezplayer is no longer supported by Toontrack but I'm familiar with it's behavior and can keep it working when if/or when it drops out by playing a MIDI file from the PT timeline. This usually resets the dropouts that occur when playing from the library sometimes.
Update: EZplayer working well using the GM mapping. This new plug-in gets extra excited with the Toontrack MIDI libraries.
Thanks Kev for the heads up on the new plug-in! I usually get my AVID email alerts the next day.
A rough sea makes a smooth sailor.
Pro Tools Studio 2023.12|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 02-13-2024, 07:36 AM
K Roche's Avatar
I hope this helps.
Thanks but
Yes, I already tried using one instrument track to instantiate the Handy Drum instrument on ,,and then Aux tracks for the different drums (like I do for Slate Drums) but then there was no signal or sound no matter what output I choose AND using all Instrument tracks is per what the instructions are on the Handy Drums website.
I have not tried Audio tracks but given Handy Drums says "instrument tracks " I am guessing audio tracks will not work either
System :
Enjoy the Journey
.... Kev...
Old 02-13-2024, 08:20 AM
K Roche's Avatar
Interesting and as I stated above "instrument" tracks is what Handy Drums says to use for the other individual drums tracks
.** I think the shortcut for Mac is Command + Shift + Opt
So to clarify you set up all the outputs on the Handy Drum first, then went to assigning the inputs on the other 9 tracks in Pro Tools ?
(I'll give that a try I do not remember which I assigned first, PT or HD )
So I did try assigning the kick tract to st1 and it works but for example---only if also assign the snare also to st 1 or st 2 (they do not come up as stereo pairs on the HD drum individual outputs ) will the snare track get a signal AND the kick track is also firing as well So yes the only configuration the plug in is recognizing is the 1-2 output it does not recognize/work on any of the rest the output numbers even though is shows then in the outputs dropdowns
Here are some screen shots of my configuration
System :
Enjoy the Journey
.... Kev...
Old 02-13-2024, 10:58 AM
Eric Lambert's Avatar
Side note: how do you like Handy Drums?
Old 02-13-2024, 11:50 AM
K Roche's Avatar
So far they sound decent but I have not really tried them in a mix or recording because I would like to get this (what looks like a routing issue ) resolved first
At first they are dryer than the Slate drums which can be a good thing IMO because I can then add in any ambience I want
System :
Enjoy the Journey
.... Kev...
Old 02-13-2024, 12:16 PM
tope d's Avatar
tope d tope d is offline
I just tried routing Handy Drums on my end and it worked.
Im on Pro Tools 2023.12.1 on Ventura 13.5.2.
Here is my routing and tracks...
File Type: jpg Screenshot 2024-02-14 at 3.14.02 AM.jpg (62.0 KB, 0 views)
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-13-2024, 12:50 PM
tope d's Avatar
Sorry, forgot to mention that the Input is set to the plugin...
File Type: jpg Screenshot 2024-02-14 at 3.48.59 AM.jpg (61.8 KB, 0 views)
-Tope
www.topedomingo.com
Old 02-13-2024, 02:24 PM
K Roche's Avatar
Hey thanks tope you for your reply. But I can not make sense of your routing scheme
It looks like you using only one instrument track to put the HD plugin on and using Audio tracks for input of the various different drums on the HD plugin ?
But it looks like the input numbers on the Audio tracks do not match the output numbers on the HD plugin So how does that work ??
For example you show the inputs for the named "SNARE' track in PT as inputs 3-4 BUT on the HD plugin you have (st 2) selected
And (assuming) the PT Audio 2 track is the Kick track. Again you show the inputs for PT Audio 2 as 5-6 but on the HD plugin you have (st 3) selected
And again assuming PT Audio track is for High Hats you show PT 7-8 But have (st 4) selected for Hats on HD
OK so I recreated exactly what I think you are doing and I get no sounds or signals in PT am testing right now
System :
Enjoy the Journey
.... Kev...
HTML code is On
Pro Tools Inner Circle AAX Plug-ins not showing in PT Insert Selector [email protected] AAX Plug-ins 7 12-21-2023 02:10 PM
TD-30 V-Drums not playing proper velocity midi hits in Pro Tools Correctly MDaveyMusic Virtual Instruments 1 01-17-2015 09:34 AM
SRS Circle Surround Encode/Decode Plug LucidMJW Post - Surround - Video 3 07-29-2009 02:39 PM
Mixer Color not work correctly with PT 7.4 massimo58 Pro Tools TDM Systems (Mac) 2 11-28-2007 05:08 AM
