#121
Re: MIDI in 2021 and BEYOND
This is all we are asking for. Let B (SEPARATE) work on the notes within the clip. NOT JUST THE CLIP BOX! Let it B
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
#122
I’m not sure about this. I’d much prefer the Logic solution of giving you options for you want to happen. A lot of the time, B might separate a note that’s just ahead of where you want to separate, or separate an overhanging note from the previous section. You’d potentially end up with two notes, an orphaned one in it’s original position and a new one where the separation is that’s no longer in it’s original position or the remnants of an overhanging note that shouldn’t be there at all.
Dave Marsden UK |
#123
#124
yes absolutely
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#125
Here is a video demonstrating it:
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#126
#127
Here's why this is not the answer for everyone: For those who in film or TV, there can often be well over a hundred MIDI tracks. With 150 MIDI tracks in Notes view you completely lose sight of your orchestration. Everything becomes visually indecipherable. You can't see where phrases start or end, and you may not see some MIDI notes at all if they're not in scroll range. Plus, a 10 second edit x the amount of times you'd have to do that in a day is an eternity when you're on a film or TV deadline. I want it to take 1 second, not 10. But here's the kicker: throw a single audio track into the mix and this doesn't work at all. ‘B’ won’t work on MIDI tracks in Notes view if there also an audio track selected. We need an easy solution like Logic's to edit both audio and MIDI tracks simultaneously. Again:
"Do you want to keep, shorten, or split the notes that cross the point where the region is being split?"
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs Last edited by SomeOtherGuy; 09-09-2021 at 11:30 PM. |
#128
I get it and you are 100% right. The feature should be there. There is a workaround that was posted earlier in this thread using a macro created with Keyboard Maestro. There should no need for workarounds for basic feature sets but at least one does exist that might work for you. I'm in pop/rnb production (at least at the moment) and have been around since pt v5 as well, but for you guys, this and the sample rounding issue are critical...so I will lend my voice as well to the cause to make midi in PT better. Ej |
#129
#130
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
2021.6 and 2021.7 restart after exit | NJsound.com | Pro Tools | 12 | 08-11-2021 01:45 PM |
Cut/Insert Time still shifting markers & MIDI clips in PT 2021.6 | take77 | Pro Tools | 1 | 07-09-2021 10:53 PM |
2021.6 hangs when deleting audio or MIDI clips | innerbooty | Pro Tools | 5 | 07-02-2021 07:16 AM |
Update to 2021.3.1 now midi and software unstable | biggamen | Pro Tools | 9 | 06-03-2021 05:54 AM |
