import Toontrack (Superdior Drummer 2.0) ?
Hi Folks
Can someone tell me how to import the magic TOONTRACK software? Would like to work with this tool as my drum machine. Tx in advance Peter |
Re: import Toontrack (Superdior Drummer 2.0) ?
It doesn't actually get imported, if you have the rtas version installed properly it will show up in the plug-in drop-down menu to be inserted on an instrument track.
003r/i7-930/LE 8.0.1 cs2 on xp |
Make sure that the Superior Drummer 2 plug-in is in your digidesign plug-ins folder.
Well, the PlugIn folder is: C:\Programme\Common Files\DigiDesign\DAE\Plug-Ins Did copy the .dll (Suprior Toontrack, EzDrummer, Guitar Rig) => opened Pro Tools => Still no Virtual Instruments visible (Suprior Toontrack, EzDrummer, Guitar Rig) Short: is there no documentation from Pro Tools side? I mean, this should be THE Tool. But where's the help for this? |
I believe there are installation notes in the Superior Drummer 2.0 package?
just clicking the installer will install things in the right place (I'm using superoior custom & vintage, and Superior 2).
You need to select an "instrument track" for the plugin to be visable in the plugin list, it won't appear in the list on other track types |
If you're a registered (legal) owner of a Toontrack product, they'll help you on their forum.
Rail
.dll are VST instruments. RTAS are .dpm. Are you running the installer correctly and selecting RTAS?
no need to copy anything - the installer does it for you, and as mentioned above toontrack has a good support forum, but you just need to run the installer
Toontrack Superior Drummer 2.0 Install | justus1900 | AAX Plug-ins | 6 | 01-26-2014 08:25 AM |
Toontrack superior 2.0 / EZ drummer playing ok with PT8? | lampmusic | Pro Tools TDM Systems (Mac) | 3 | 01-26-2009 02:51 PM |
Ez-Drummer and Superior Drummer by Toontrack | Narzugon | Virtual Instruments | 3 | 12-17-2008 08:06 PM |
How Do I Use Toontrack DFH EZ Drummer in Pro Tools | cba1951 | Virtual Instruments | 3 | 02-07-2007 11:11 AM |
Anybody using Toontrack EZ Drummer | The Dougfather | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-21-2006 12:53 PM |
