Upgrade from 001 to 002 question...
If I'm planning on upgrading from a 001 to 002 (not R), and run PT 5.3.2, do I need to upgrade my non Digi-rack plugins or can I simply install it over my existing ProTools and lave my plugins intact.
My hunch is that my other plugins would be OK since both PT versions work on OS9. The third party Plugins supported on my 001 would still be supported on the 002 when using PT 5.3.2. Thanks!!
JC Richardson C.A.S. Magick Lantern Atlanta |
Re: Upgrade from 001 to 002 question...
Unless im mistaken,
digi 002 or 002R will not run any version of Protools in OS9. |
the 002 came out while PT5.x was still supported. the 002 rack however won΄t run in OS9. check this: http://akwww.digidesign.com/support/...d_with_002.pdf regs
last: PT11.3.1 |
Which version of Pro Tools were you running before?
All plug-ins after 5.3 won't run with previous Pro Tools builds (and vica versa). The DAE was changed to a DLL with 5.3 Rail
Thanks Rail, just the info I was needing and unable to locate!!
Mac Upgrade Question | Rayvenx2208 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-24-2010 08:53 AM |
Upgrade question - can I use mbox2 micro upgrade on 002 system? | spreston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2009 11:22 AM |
Upgrade to 003 question | Jamtime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-29-2007 02:42 PM |
To upgrade, or not to upgrade? 'Tis the question.. | knewbee | Pro Tools TDM Systems (Mac) | 5 | 03-07-2005 09:09 PM |
to upgrade or not to upgrade, that is the question | paul m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2004 12:01 PM |
