Old 06-08-2022, 10:15 AM
Goombot Goombot is offline
Default Clip gain presets
Ideally I'd like to keep my clip gain nudge value at .5db but have a preset or some way of hitting a button and have my clip gain either boost or cut by 5.0 db. Is there any way to do this? You can't audio suite because that resets the clip gain to 0.0. I wish Avid would have Clip Gain presets.
Old 06-08-2022, 12:17 PM
Default Re: Clip gain presets
You can AudioSuite it and keep your existing clip gain if you set the AudioSuite plugin to Clip By Clip and Individual Files. In that case the Handle Length box at the bottom right comes into play. You can set the amount of handle that remains in the new file to an amount of seconds, or have it render the Whole File. But keep in mind that using AudioSuite will create all new audio files and start to eat up hard drive space.
Scott Gatteño
Old 06-08-2022, 12:32 PM
I appreciate the answer but that’s not what I’m looking to do. Thanks
Old 06-08-2022, 12:45 PM
Understood. I was just clarifying that there is a way to AudioSuite without the Clip Gain getting reset to zero.
Scott Gatteño
Old 06-08-2022, 02:24 PM
JingleDjango JingleDjango is offline
I like the idea of clip gain presets. My workaround is to use Keyboard Maestro to trigger the gain up/down function by X times.
Old 06-09-2022, 05:00 AM
Sardi Sardi is offline
Exactly what I do, but I still find myself changing between 0.5db and 5dB settings.
Need to look into KM and see if there’s a way to speed up the triggers which would mean I could leave it set like you do. I have a 10dB clip gain macro for de-breathing which would require MANY triggers if set to 0.5dB.
Old 06-09-2022, 05:32 AM
marsian marsian is offline
I'm interested in a faster way, too.
I also use KM with many triggers to get breaths down.
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 06-09-2022, 07:34 AM
No, I'm with you. For de-breathing VO I do often wind up adjusting the increment. My usual macro will separate the clip and gain down 4 times and I change the gain value depending on the project specs. It's true that too many keystroke actions in a row can cause slowdown. I took the time once to make a macro that would call the Preferences dialog and adjust the clip gain increments automatically (mostly based on Find Image actions) but in the end I didn't think it offered much convenience over doing it myself.
Old 06-09-2022, 01:23 PM
It’s not the answer you’re looking for, but I always use the mousewheel for clip gain (like you I normally have it set for 0.5db). The wheel is great for making big changes very quickly, I find, so reducing by 20db only takes a second or two even at the 0.5db setting.
The only drawback is if you undo - that’s really tedious!
Guy Rowland
www.guyrowland.co.uk
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 06-10-2022, 07:17 AM
That's not a bad way about it and I used to do it that way myself but I found that my hand would cramp up during longer edit sessions from the repetitive strain of scrolling.
Clip gain o Gain plug in Camilo Toledo Foro en Español 3 03-22-2017 02:10 PM
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
