Can't Paste plugin settings with shift/command V
Does anybody know what gives? I'm running 12.4.0 HDNative on a MacPro Cheese Grater tower running 10.10.5
I used to do shift/command C, shift/command V to copy and paste plugin parameters from channel to channel (option dragging the plugin when there's one already on the target track seems silly to me) Ever since making the jump to 12 I haven't been able to do this. I just did a fresh install on a freshly formatted machine and I still have this problem. Am I the only one? -Greg |
Re: Can't Paste plugin settings with shift/command V
Works great here. Are you sure the plugin window has his target button enabled when you hit the shortcut ?
It would be great if Pro Tools could simply copy and paste an entire plugin chain as you can do in WaveLab, Reaper, and Logic Pro without creative workarounds.
It's 2016. |
If your plugin chains on each track match slots, you should be able to do this by adding option to the key command? I seem to remember doing this a while back.
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
I'm having the same problem. Keyboard shortcuts elsewhere work OK, but the Shift-Command-C and Shift-Command-V to copy and paste parameters from one plugin to another do not work. Funny though, it used to work fine and then stopped working.
Running PT 11.3.1, Mac OS 10.8.5., MacPro tower mid 2010 |
C24 copy/paste settings | tamtamstudio | ICON & C|24 | 4 | 05-01-2016 12:19 AM |
Copy settings, paste settings ? | Terry Wetzel | General Discussion | 6 | 04-03-2016 06:13 AM |
Paste automation command error | Drywsef | macOS | 3 | 12-19-2013 02:29 PM |
Using copy and paste command | hyrobase75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-13-2004 10:42 PM |
any command 8 cut & paste hotkeys?? | zenmango | ProControl, Control|24, Command|8 | 0 | 07-06-2004 04:07 AM |
