Using Apogee Trak2 D/A to listen via monitors
Ok
I have searched quite a bit, but have failed to find a comprehensive answer. Sorry if I missed it. I have a Trak2 with the 8 D/A option. I am running PTLE 6.2.2 on a 002. So, I purchased the Apogee cable (Db25 to 8 XLR male) I have Event 20/20 BAS monitors. I plugged in 1 and 2 from the snake into the monitors but need to know the next step. i.e. What settings do I have to switch to hear sound out of the monitors? Thanks. Please ask if there is any helpful info I may have left out. -rw www.russellwolff.com
www.russellwolff.com I produce things @ www.krazypopstudio.com Endorsements and affiliations: MikTek Microphones, AVID, Klotz Cables, CAD Headphones, ToonTrack, Parker Guitars, Taylor Guitars, Steven Slate, Seymour Duncan Pickups, D'Addario, Bugera; Dangerous Music, Digidesign, Focusrite, IK Multimedia, Altiverb, Focal Monitors, and SurgeX. Pro Tools 12.4 HD, MBP Quad-core 2.5Ghz i7, 16GB RAM, UAD-2. Interfaces: UA Apollo 8 |
Re: Using Apogee Trak2 D/A to listen via monitors
Hi Russell. If you are using your S/PDIF I/O, try these settings, if you haven't already. I use the same with a 001, Apogee Mini-DAC and Mackie HR824s(It should be the same for the 002):
To select the Clock Source: 1 Choose Setups > Hardware Setup. 2 Select a clock source(S/PDIF) from the Clock Source pop-up menu. Select the sample rate. Then select S/PDIF Mirroring(when this option is enabled, the S/PDIF (RCA) outputs (outputs 17 and 18) automatically mirror the audio that is sent to analog outputs 1 and 2). 3.Click OK. Can you now monitor your session out of the Trak2? Let us know. |
I am being told by Apogee that the Trak2 has no digital in by default. So, while I use the SPDIF out to go into the 002, and I use the clock via SPDIF, is this true? Some people are telling me there is a way to get back into the Trak2 out of the box. Apogee is telling me I need to buy an AMBUS card with ADAT optical in to get back in. Any thoughts? Thanks.
I want to listen watch and listen to tutorials and have PT coming through my monitors | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 3 | 10-15-2012 07:48 PM |
Apogee Trak2 with TDM vs LE | jonnyrocker | Pro Tools TDM Systems (Mac) | 3 | 07-19-2003 01:55 PM |
Apogee TRAK2!!!!!!!!!!!!!!! | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 11-14-2001 11:22 AM |
Apogee Trak2 | Bryan | Pro Tools TDM Systems (Mac) | 2 | 04-24-2001 07:13 PM |
Apogee Trak2 | verfonce | General Discussion | 1 | 08-30-2000 05:27 PM |
