Strange problem with audio/midi tracks after copy/duplicate
Hello!
I discovered a strange Problem on Protools LE 9.0.3/9.0.5!!! independent of session or Computer: After copying OR duplicating Audiotracks/Miditracks a few times (sometimes after the first, sometimes after more copies) the right end of the track is not on the Grid anymore. --> you can only see this when zooming to maximum!! Settings are on "Grid", tried it with "Sample" based and "Tick" based too. I also tried it on another Computer with PT 8 and a PT HD5 and the Problem did NOT appear! Its bad, because you cannot just copy/duplicate right on, you need to check every right edge of your Files manually, because if you just copy on, your sound will change after 3-4 minutes. I checked it with a Click Audiotrack set perfectly on the Grid and put into a Group, with the Edges perfectly cut. After duplicating about 3-4 minutes you will hear its sound starting to change -> i have put it over a midi beat, which was set correctly "manually" until the end. This means: your Music will NOT sound the same at the End. Its very little but i think this is not ok. Its causing phase Problems and other Things because its happening randomly. Any Ideas?? Thank you very much!! :) (i use iMac i7, 2,9/12GB with OSX10.6.7 and Protools LE 9.0.5) |
Re: Strange problem with audio/midi tracks after copy/duplicate
I have the same problem with Pro Tools.. the bar doesn't reach the end of the grid after duplicating just a few bars twice!
Does anyone know if there is a fix for this? I'm running 8.04 on a macbook pro |
From the manual:
Sample Rounding and Edit Operations When audio material in Pro Tools is samplebased, some amount of sample-rounding may occur with some edits when the Main Time Scale is set to Bars:Beats. This is most evident when you need audio regions to fall cleanly on the beat (as when looping) and notice that the material is sometimes a tick or two off. With a few simple precautions, this can be avoided. To ensure that selections are precise aligned to the grid for looping, copying, duplicating, or repeating, consider the following: If you use the Selector tool, enable Grid mode and select the appropriate grid value (such as sixteenth notes). For the greatest accuracy, type the selection Start and End points in the Event Edit area. Do not select the material with any of the Grabber tools (or by double-clicking with the Selector tool).
Midi Editor Copy/Duplicate Leaves off Notes | anackman | macOS | 2 | 10-11-2012 09:31 AM |
Smile Strange problem with audio/midi tracks after copy/duplicate | Nullfusion | Pro Tools 9 | 1 | 09-16-2011 04:35 PM |
midi copy/duplicate: 7.4 can't grab 1st quantized note | glankrudolph | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 12-16-2008 07:33 AM |
copy or duplicate midi parts crashes PT MP 7.1/7.3 | Fishbone | Pro Tools M-Powered (Mac) | 2 | 01-22-2007 11:56 AM |
strange intermittent duplicate command problem | PeterScherr | Pro Tools TDM Systems (Mac) | 1 | 08-30-2005 09:09 AM |
