creating dae objects.......
Hi to all.
first time i open ptools LE in the morning, starts to load and when it gets to "creating DAE objects" ptools freezes! No messages, no shutdowns! just freezes! i ctrl+alt+delete and it shows "protools LE is not responding" and cpu it's at 7-8% I then restart the PC, open ptools again and everything goes ok! Anyone with this trouble? ___ 002R Ptools LE 7.3.1cs6; Reason3.0; ASUS p5k deluxe; Pentium Core2 Quad Q6600 2,4Mhz; 2 Gb Ram ddr3 1066 Kingston; 2x500Gb Seagate SATA2 |
Re: creating dae objects.......
Not sure but it may be a firewire hangup...u could try switching ur firewire location that the interface is running to on ur computer or even the firewire cable itself if it continues to happen...
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well. |
Many thanks for your answers.
Well, i use the stock onboard firewire coming with motherboard asus p5k. i know many use them as i see here in the forum, without issues. i've tried one thing: 1st-switch on 002R 2nd-switch on PC 3rd-load ptools And it worked, so i suppose it's a firewire problem?? Thanks |
CREATING DAE OBJECTS quits pt hd | hectorjr | Pro Tools TDM Systems (Mac) | 1 | 03-19-2012 07:56 PM |
PT 7.4.2 hangs on creating DAE Objects. | mikeyb91599 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-19-2009 03:57 PM |
PT 7.4.2 hangs when creating DAE objects | mikeyb91599 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-29-2009 05:57 AM |
creating DAE objects | DanX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-30-2007 09:03 AM |
creating DAE Objects | euphjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-29-2004 02:40 PM |
