Old 10-13-2004, 03:48 AM
deltacon deltacon is offline
Default Newest WaveDriver Logic Audio Error -6006 on start
My problem: everytime, when I start Logic Audio Platinum 5.5.1, I get an Error "Can't initialize Direct I/O. Direct I/O driver returned Error -6006".
I searched the answerbase and found out, that thise means, my Digi001 extension is turned off, but it isn't.
I'm running Windows XP Pro on an AMD Athlon 800 (on a board with VIA chipset - newest VIA4IN1 installed).
Wavedriver is installed but deactivated. Digi001 was still running on this computer/configuration, but I had to re-setup my system and with the newest wavedrivers it doesn't run anymore.
Pro Tools is NOT installed, because I'm not using it. In my previous installation I was using the Wavedriver 1.7.1 with ProTools LE 5.3.1 installed.
Do I have to install ProTools again (because the wavedriver 1.7.1 does only work with installed ProTools) or is there another chance to get this sh... running?
If so, how can I uninstall the newest Wavedriver again?
thanks for your advice
best regards
bernie
Old 10-14-2004, 08:55 AM
Default Re: Newest WaveDriver Logic Audio Error -6006 on start
get it up once...no ideas?
PT4CS2_M-Audio Delta1010 error 6006 encountered eddiewes Pro Tools M-Powered (Win) 1 01-17-2008 03:03 AM
DAE ERROR -6006 MICHAELING Pro Tools M-Powered (Win) 4 11-11-2007 07:47 PM
Hi there i got error 6006 ? phatbazz Pro Tools M-Powered (Win) 4 03-11-2007 11:49 PM
DAE error 6006 mingustoo Pro Tools M-Powered (Win) 2 12-13-2006 08:32 AM
error -6002 in pc by logic start rewo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-01-2001 04:51 PM
