Help 003 will not power up
Help 003 will not power up after a windows vista installation, it was working perfectly in win xp has this happen to any ono else?
Ross |
Re: Help 003 will not power up
When you say it won't power up - do you mean it actually does not come on when you press the power button?
If so - you should contact tech support by phone for assistance in diagnosing the problem and getting it repaired. |
The Actual installation of any program or OS in your computer should have not made any negative electrical effect on the unit, You could power up, Turn on and turn off a 002/003 even if it is not plug to a computer. If your 003 does not turn on, you may have an electrical problem with the unit or in your set up, or somehow during the OS installation, it was on, and you may have fried the power harness or the unit. Have it checked.
Camilo Toledo |
[QUOTE]
When you say it won't power up - do you mean it actually does not come on when you press the power button? thats right but the little green light at the back is on. is this a comon problem the unit is not very old. I was aware of the 002 power harness problems this is why i got the 003 cant win I guess Ross |
Its going to the shop to be repaired today and if it turns out to be the dreaded power ribbon I shall want my money back DIGI??
Would this UPS (Uninterrupted Power Supply) protect and power my gear? | D_Japan | macOS | 4 | 07-24-2011 04:23 PM |
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
Correct Order to Power Up & Power Down Digi 002 Rack? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-12-2008 06:57 AM |
Mbox 2 power consumption? How much of a power load is this | spaids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-30-2007 06:27 AM |
002 rack power harness power suplly issue | rockstah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 11:04 PM |
