Re: Will Beat Detective do this?
Yes. Get one. I can't imagine using my Mac without a 2-button mouse any more...
Right click is a HUGE time saver with 7.3.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
If I follow your process correctly, you have a bunch of tracks that each have a single region in them played by the Yamaha, but they are out of sync.
Can you not just switch to the bars/beats grid, visually trim the head of each region to the start of its sequence and snap the start to the grid? You could then nudge any regions that don't sound tight. Hopefully the Yamaha is not changing tempos on you, so in theory each of the sections you have recorded is at the right tempo, but the start just needs to be aligned. No need for beat detective to do this. In the future, I would learn how to send a midi message to trigger the Yamaha to start playing, then this sync issue will be gone. Much, much easier.
Recording artist/Engineer/Producer Waves beta tester |
JEFF,
I was not aware PT could send such a message. Does that have something to do with the Clock? I would simply need to transmit a message to Channel 1 in the XS. Wheere do I set that up in PT? I no longer have a manual, and PT "HELP" file DID NOT DOWNLOAD when I spent my $75 on the 7.3 upgrade. |
Hah! Idiot me and my new iMac
I wrote"
I am on a Mac, no left and right button on mouse - so how do I implement? Duh to the max, because the new iMac comes with a mouse that tilts to the left and right and clicks....only took me three weeks to figure out I have a "right" click mouse. Love "snap to" ability..... |
It would be better to sync the two machines, but the method above would work assuming there isn't a huge drift in the clocks of the two systems. If there is, and you are tracking repeating parts, you could always just manually quantize the first occurance and duplicate it, but you would have to match tempos. You should also be able to record the midi that the keyboard is generating into protools, which would be my prefered way of doing this. Just assign each instrument to a different midi channel on the keyboard, then set up tracks in ProTools assigned to single channels. One record pass does 16 tracks. You can then get ProTools to play the keyboard while you record the audio onto new audio tracks, which will now all be in sync. This would also allow you to fine tune the sequences in ProTools using midi, which is much easier than manipulating the audio. You should be able to download the help file by going to your Digi account.
Beat Detective/Quantize Swing Beat | anackman | macOS | 1 | 10-15-2012 07:10 AM |
Tempo mapping Beat Detective or identify beat? | grateful | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2012 09:13 PM |
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! | Robbry | Pro Tools M-Powered (Win) | 0 | 02-24-2010 02:14 PM |
what do grid lines do after beat detective bar-beat markers | cc1 | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 09:34 AM |
Beat Detective, Beat markers to Tempo Ruler?!? | phobia | Tips & Tricks | 3 | 01-01-2007 01:31 PM |
