Dock automation buttons can't be reassigned
I want to reassign the automation buttons on the left edit side of the Dock. Unfortunately the left column can't be reassigned to anything at all. Neither in Pro Tools nor in any other DAW. It just sticks with the default assignment. The right column on the other hand can be reassigned. Can someone confirm that this is a bug? |
Re: Dock automation buttons can't be reassigned
It works fine here, i am on Cubase Pro 11/Mac (all latest FW).
It worked also with older versions but i remember, when i was programming the editor was automatically renaming the buttons on right side but for the left side it left them blank and this made me think the programming was not being saved but actually they worked. I had to later manually relabel them. Though the the buttons with red/green lights...they do not correspond with Cubase's automation state etc. The Editor is a delicate piece from stone ages, the one and only true VINTAGE software out there hence Avid is updating it 1/2 (you can read this as "1 or 2" or as 0.5, the ladder is more accurate though) times a year, they need some permission from government before they can make changes to it....handle with care :) |
Found the solution. I had to switch off the following setting in EuControl:
"Dock automation mode buttons follow attentioned channel" |
Dock: "OK/Cancel" buttons not working?? | docric | Avid S1, S3, Dock and Control App | 5 | 07-20-2022 12:51 AM |
Automation mode buttons not working | CalleWay | Avid S1, S3, Dock and Control App | 7 | 09-22-2020 09:26 AM |
New Dock.... flakey right side buttons | mattrixx | Avid S1, S3, Dock and Control App | 26 | 09-09-2017 01:26 AM |
Dock Automation Buttons bug? | feakerboo | Avid S1, S3, Dock and Control App | 0 | 04-27-2017 08:02 PM |
Upgraded to PT 12.5 now automation buttons not working | bassmagnetic | Avid S1, S3, Dock and Control App | 3 | 06-13-2016 08:15 AM |
