Unable to communicate with hardware launching 6.4 LE w/ 001
I just built a new system and I can't get my 001 to work. Any ideas?
Asus PK5 SE Motherboard Intel XEON 2x3.0ghz eVGA geforce 8400GS 256mb (PCI-E) 2x1 GB DDR2-1066mhz OCZ RAM 250 GB Seagate 7200RPM 8MB Cache SATA2 System Drive 500 GB Seagate 7200RPM 32MB Cache SATA2 Audio Drive Protools 001 Card Windows XP Professional (SP2) & Pro Tools LE 6.4 Everytime I try to launch protools it starts loading, then it sticks on 'Creating DAE Objects' and a window pops up saying "DAE was unable to communicate with the audio hardware. Please save your session and restart your computer. (-6004)" I've updated the PACE drivers. I'm running SP2 - I know this hasn't been tested by Digidesign - could this be the issue? I can't downgrade though, because it's straight from the install. I've tried disabling the AC97 sound and network adapter. I've tried switching PCI slots. I've updated my bios, etc. I'd love some advice! Thank you. |
Re: Unable to communicate with hardware launching 6.4 LE w/
Does anyone have any ideas? I've been trying everything.. I'm desperate to make this work.
Someone will certainly have a more complete answer than this one, but update to PTLE6.4 CS6, then CS9 to use with XP SP2. They are free. That's my big idea. Wishing you the best!
Digi002R PT2018 Win 10 INTEL Core i7 930, 3.52 Ghz GIGABYTE GA-X58A-UD3R CORSAIR XMS3 12GB 1600Mhz 2 X WD 1TB Caviar Black 64 GB cache MOTU Traveller PT2018 MacBook Pro Mojave 16GB DDR3 |
Hey Kirby, thanks for the suggestion. It was a good idea, but unfortunately it didn't solve the problem. Still looking for ideas..
Since you have a dual core, you may have to turn one core off.
Cheers,
How do I turn one core off? I read about that somewhere, but I wasn't sure how to actually disable one core for pro tools.
I set the affinity to only use one core and it didn't help the problem.. I ran 'digitest' and it says it failed the 'bus master test'. It still works in my old computer - the 001 isn't defective. I used a friend's copy of SP1 just to test to see if that was the issue.. Same problem, so now I've reinstalled my SP2 copy of XP, and installed all updates.
This HAS to be a hardware thing, right? Is it possible the 001 isn't getting enough power (current) through the PCI bus? Or, maybe is there a way to change the IRQ it's using (besides switching slots)? It's on IRQ 16 and the other slot is IRQ 17. These are shared with sound / ethernet, but I've tried disabling everything in the bios so the 001 has it's own IRQ and it still gives the same error on launch. I've got a 500 Watt power supply, so it's not starving from watts. Any more ideas? I have a Black Lion 002R on the way in about three weeks, but I'd love to get this working - as I've got a couple of projects starting in the next day or two. |
Anyone? I'm about to take an axe to the 001 and my new computer. Well, not actually - but, I've exhausted every option in my head.
I'm getting the same error with a similar setup. Anyone else have any ideas? S.J. did you find a fix?
i AM HAVING THE SAME PROBLEM SOMEONE PLEASE HELP
PT is unable to communicate with HUI - HELP!! | gpbuil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-03-2008 11:23 AM |
DAE unable to communicate with hardware | GuyPicks | Pro Tools TDM Systems (Mac) | 2 | 03-06-2007 09:25 AM |
DAE was unable to communicate with Audio Hardware | harrillj | Pro Tools TDM Systems (Mac) | 1 | 12-31-2006 05:59 AM |
"DAE Unable To Communicate..." | Sounder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-20-2000 12:15 AM |
Unable to communicate with HUI... | uno1234 | Pro Tools TDM Systems (Mac) | 8 | 02-01-2000 10:07 AM |
