Re: DAE Error -9131.... Yes, the dreaded -9131.
What plugins have you installed?
Is there anyother hardware attached? anything you may not have mentioned? I noticed on your last post that you have a 5400 rmp drive... everyone I know runs at 7200 rmp.... this may be the issue???? DD? I would suggest that you use the external drive until you get this problem sorted. |
Which drive are you trying to record to?
If you're using the FW drive - does the drive have a FW800 port and are you possibly using a FW400 to FW800 cable? |
oookay so,
I haven't got any plugins installed (only those that come with PT LE) I don't have any hardware connected (only Mbox2) I tried both USB ports of the macbook for the Mbox2 I tested with my external HD (Lacie D2 250 Go) but it doesn't work (same error) the drive I'm trying to record to is my internal HD (TOSHIBA 60Go 5400RPM) but as I said it also doesn't work with my lacie, so I guess it is not a HD problem (I might be wrong) but more a software issue. I might add that I have Logic Pro 7.2 installed (with no additional plugins) and that the mbox2 works well with it (with the core audio driver). I also add that I can monitor inputs when I arm a track for record (not only in direct monitoring) I even added plugins (EQ, comp, etc.) I imported some audio files that I had on one stereo track and tried to create and edit some fades. Curiously the speaker icon in the fade editor works, and I can hear the result of fade in/out and crossfades. BUT, when I click "done" and go back to the timeline, playback doesn't start (again error 9131). This is insane.... let's find a way out of this guys, please !!! thanks, Robin PS : some additional info on my computer system : Mac OS X 10.4.7 (8J2135a) Core : Darwin 8.7.1 Boot ROM version : MB11.005F.B00 Macbook serial # : 4H6240BLU9E SMC Version : 1.4f8 Hard Drive : capacity : 55.89 Go Model : TOSHIBA MK6034GSX Révision : AH105B serial # : 56BO3072S GUID partition table 1 partition MacOS extended, journaled, case sensitive
MacBook intel 2Ghz - 1 Go RAM - 60 Go TOSHIBA internal drive 5400 RPM - MBOX 2 - PT 7.1.1 LE |
hi, i think i have the same problem as you. when i open a session (old, or new is the same) PT works for a few minutes then it stops. if i push play again it starts to play a loud noise just for a few of seconds then it stopa again. i try everythig but nothig seems to work. repaired permission, trash the preferences, but nothing, can it be a macbook problem? the only difference is that i huse an mbox and my error is 9136.
can anyone help me? tanx stefano. |
problem solved !!!
I tried to record on another external drive (which was formated with macos extended, not journaled, AND NOT CASE SENSITIVE) and it worked, so I reinstalled macosx by reformating my macintosh HD with the same format. now everything is ok !!! the only problem is that I'm gonna have to reformat my lacie with the same options (250Go...) but whatever. People at digidesign please indicate this on your web support, this was very annoying... pro tools LE 7.1.1 does NOT work with drives formated with the "CASE SENSITIVE" option bye, robin
The dreaded DAE 9131 message | mholley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-01-2008 01:58 PM |
Dreaded DAE Erro -9131 | a2zproductions | Pro Tools TDM Systems (Mac) | 2 | 01-03-2007 02:45 AM |
Dreaded 9131 | BigBobMXMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-14-2006 10:50 AM |
DAE error -9131 | jaywynne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-06-2005 02:21 PM |
The dreaded DAE Error 9131 | David Lang | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-04-2003 02:30 PM |
