No audio out
I apologize for the very newbie post. I am trying to do a quick evaluation of Pro Tools and the Blackmagic UltraStudio 4K Mini interface. I have imported an .aaf file from Resolve and and looking to see how well everything works together.
I have figured out how to get video to my reference monitor from the US 4K Mini but sound is the issue. Through the US 4K Mini I can see audio waveforms on the device, and hear audio from the headphone jack. However I cannot hear any audio going to my speakers from the back of the US 4K mini. I have my out on the track set to "Out 1-2". I have my Mac OS set to the US 4K Mini in and out sound. And I can see the audio waveforms on Pro Tools and the US 4K Mini. I was just wondering if anyone had any thoughts as to what I am doing wrong. Again, thank you for the help. |
Re: No audio out
The audio settings of macOS is not for PT.
Go to PT menus "Setup", Playback engine and set it to your interface.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: No audio out
I should have mentioned I have that set for the US 4K Mini device already.
Re: No audio out
What Mac OS version are you running ?
#1 So you have the 4K selected as your playback engine #2 You have the 4 K selected as the Mac Sound In and Out #3 You have the 4 K selected in the Mac Audio Midi Set Up as the input and output #4 In PT Setup I/O the 4K is showing and you have Analog 1 &2 selected as the output monitor path #5 And you have your speakers connected to the analog out 1 &2 on the 4k You say you see the audio waveform in PT BUT are the track meters showing signal when you are in play ? Then You might want to trash PT Preferences and relaunch PT
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
Re: No audio out
I am running 10.15.7 Catalina.
#1 - #5 were set as you described. I also saw the audio meters showing signal and I could get audio from the from headphone jack in the US 4K Mini. However as I played with it some more I also realized that there was no audio coming out from anything I tried, not just Pro Tools. I did not trash the preferences but booted over to my other drive which was running Big Sur. I confirmed that everything worked correctly, in multiple programs ( not Pro Tools) and rebooted back into Catalina. I opened up the Blackmagic Desktop Video Setup app and made sure everything was set correctly there. I did not change any settings. I tried audio again on everything and it all worked, including audio out on Pro Tools. And I have no idea why. I play with it for a day and see if it happens again. shrug. Also the system specs for this are 2019 MacPro OS 10.15.7, 3.2GHz 16 Core, 160GB Mem, 4TB Drive, 8TB Internal Sonnet Raid, Dual Radeon Pro W5700X 16GB LG UF 5k, 27" Tbolt Display, 55" LG C8 Thank you K Roche for helping me out with this. |
Re: No audio out
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
Audio Suite process puts new audio in audio bin | Fritz12534 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-21-2009 08:55 AM |
PRO TOOLS giving 2 Audio track ''Audio 5_02.L and Audio 5_02.R'' | fredson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2008 09:08 AM |
How can I bounce mutliple audio/instrument tracks as mono Audio files in ProTools LE | thaprof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-16-2008 11:03 AM |
USB2 Audio HD vs Fw Audio HD vs internal audio HD | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2005 02:06 AM |
