Old 01-16-2013, 02:02 PM
Cawbaby Cawbaby is offline
Default Solo-safing in AFL mode?
Recently set up AFL/PFL capabilities for my D-Command. Everything works as expected, though for some reason when AFL or PFL are enabled my fx returns mute when I solo a track.
For example, my whole mix is up and there is reverb on the vocal; but when I solo the vocal, the reverb is in turn muted. The obvious fix would be to 'solo-safe' the reverb send, one would think. Though while in AFL or PFL modes you cannot solo-safe tracks. When you hold command and click on the solo function, instead of graying out (typically indicating solo-safe functionality) the AFL/PFL volume fader pops up instead.
Any ideas?
Dr. Caw Recording
www.drcaw.com
Old 01-16-2013, 03:57 PM
Drew Mazurek's Avatar
Default Re: Solo-safing in AFL mode?
Any ideas?
There is no solo safe in AFL/PFL as they are non destructive in nature due to the fact that it's a separate buss and does not use the Stereo Buss.
When using the AFL/PFL solo modes, only the channels soloed will play through this dedicated buss. So to hear the verb, it will also need to be soloed. It sounds to me like you want to just use the regular Solo In Place mode with your returns "safed"
www.drewmazurek.com
Old 01-21-2013, 11:39 AM
thanks as usual, dmaz. got everything in a working order at this point. i appreciate your expertise.
Dr. Caw Recording
www.drcaw.com
Old 01-21-2013, 11:41 AM
Happy you got it sorted. Glad to help.
www.drewmazurek.com
Old 01-21-2013, 12:44 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
AFL is needed when mixing "on air".
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Solo mode bug or me? Dallas Taylor Post - Surround - Video 10 09-27-2014 12:50 PM
Slow Solo mode T S Artist Series 2 02-24-2012 04:45 PM
Solo Mode Setting not persisted in 2.6.2 DhyanMikael Artist Series 0 01-06-2012 03:43 PM
AFL Solo mode and solo trim brenttrf VENUE Live Sound Systems 2 09-18-2010 12:44 AM
Is there are new solo mode or am I doing it wrong? derF Pro Tools TDM Systems (Mac) 6 03-02-2009 09:35 AM
