Protools 8 bug -separate region hangs protools
Using the "b" shortcut to seperate a region hangs my system
imac 2.66 - digi 002 - external lacie drives. any ideas I trashed all prefs etc - I can't edit. Now I have to talk to my wife |
Re: Protools 8 bug -separate region hangs protools
I had this problem once, and besides deleting prefs and databases, deleting digisetup.osx
http://www.jcdeshaies.com/ try the helper app, delete everything with it, than empty trash, restart. This method worked for me. Tamas Dragon
my blog:Tamas Dragon |
Had the same issue, seems like the above solution worked for me, definitely had to toss the digisetup.osx as just trashing prefs and databases alone didn't solve it.
It is a known thing with pt8. Switch off "separate region operates on all related takes" in the preferences edit tab, and problem solved forever.
I mean I hope they will fix this, but if you switch this off, you'll be fine. Tamas Dragon
YES! The problem returned after I trashed all my pref's and reset them. This was it. Thanks |
When hilighting a region protools hilights same region in ALL tracks! | djcnote | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2010 11:29 AM |
ProTools Le 7.3.1 Hangs up! | Rajan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-11-2007 10:36 AM |
ProTools 6.9.1 and 7.1 on separate partitions? | FDurrett | Pro Tools TDM Systems (Mac) | 4 | 07-18-2006 03:43 AM |
Separate ProTools/ Final Cut Pro set-up? | Macavity93 | Pro Tools TDM Systems (Mac) | 1 | 07-01-2003 07:27 PM |
ProTools hangs | uno1234 | Pro Tools TDM Systems (Mac) | 5 | 10-14-2000 12:16 AM |
