Re: MTRX Studio distortion on outputs
ah ok, that 6dB button is a MTRX Studio only button. The monitor outputs (so the TRS sockets on the unit) have up to +24dbu headroom by default, the line outputs up to +18dBu . Not sure how that +6dB button works exactly in practice, as I don't the studio but the MTRX. But as it seems from the manual that button scales up the analog line outputs from +18dBu to +24dBu . If you have the Cadac live which can handle up to +21dBu , you could click the +6dB button and trim off 3 dB to output exactly +21dBu . Or, if you want to match your Lynx Aurora for instance, which is +20dBu on the outputs, click the 6dB button and trim off 4dB.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
I am not at the studio right now. But i'll do your test as well to see where i am exactly in the dB range. Although i did the test this in an implicit way. I output a mix trough PT at lets say a safe max -1dB FS, garded by af FABfilter limiter. Next i did set the desired level in DADman at the levels. Not even close to the plus 18dB as indicated as example in the Avid instructions page. Then i get a lot of distortion. It's not the console (analog Cadac) or the passive monitor control. I can dim the monitorcontrol. It is MTRX. that sends out a distorted signal. |
Another question: Does your MTRX's show an digital overload on the meters? I cant even force one on mine. |
Haha no worries men, we happend to reply at the exact same moment, didn’t want ignore anything:)
#16
I think it would benefit all parties in this thread to wait until you can get back into your studio and do a proper signal flow test from source to destination. If you send a 1k tone @-18dBFS from Pro Tools that should measure 0VU exactly on your console's analog input. Any other measurement, distortion at that level, or reduction in signal level would indicate an issue somewhere in the chain. BTW, I'm referencing -18dbFS since that is the European scale for 0VU |
#17
#18
I’ve experienced this with other equipment where there was a mismatch in balanced/unbalanced configurations, or an mis-wiring in the cabling (such as swapping “ground” with “-“ on an electronically balanced output feeding an unbalanced input).
Is that a possibility? Are the DB25 cables you are using factory built? The right pin out? Etc? |
#19
Hi All,
Thanks again for all your comments. It is solved by all your contributions. I did the test as its2loud suggested. Tone_Mechanic is right. MTRX is sensitive to balanced /unbalanced. This is the cause of the distortion. The Lynx and Apogee don't react to that. The outputs sound the same. If i connect the MTRX to an unbalanced input the output of the MTRX starts to distort quite soon: above 0dB in DADman. The faders in DADman control the analog output. It has nothing to do with digital gain. Some tape returns on old consoles are unbalanced. I also use the insert return as an unbalanced line input after EQ to skip electronics. So users of old console/mixers: you can't do this with an MTRX. MTRX is balanced only. I also used an unbalanced monitor input. The Benchmark is allright with that. But the MTRX not. Now it's connected balanced input and i can turn up the output to max without issues. Thanks again all of you! So much wiser in 24 hours. And i can keep the MTRX Studio happily. @Tone_Mechanic do you have fix for the unbalanced issue? A different way to connect balanced to unbalanced? |
#20
https://www.ranecommercial.com/kb_ar...p?article=2107 (it is best to make short patch cables that "adapt" than tinkering with a DB-25 breakout cable that is wired to the normal standard -- and then label those patch cables for what they are) or you can use a balancer box. (There are a lot of different companies that make them) For instance https://www.ranecommercial.com/legacy/bb44x.html
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
MTRX Studio Headphone Outputs vs HD Native Thunderbolt Box | scottmckay | Pro Tools | MTRX & MTRX Studio | 3 | 07-28-2022 09:22 PM |
MTRX MTRX Studio Forum Section? | off the wall | Pro Tools | MTRX & MTRX Studio | 2 | 05-08-2022 03:20 PM |
MTRX Studio & AES Outputs | talkbacksound | Pro Tools | MTRX & MTRX Studio | 25 | 01-28-2022 06:42 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
MTRX Studio and Rednet PCIeR card - no outputs above 32 | ampnerd | Pro Tools | MTRX & MTRX Studio | 4 | 06-25-2021 09:02 AM |
