Question(s) about The Allenstein Machine..
I've looked at the said websites in search for the parts listed under the Allenstein Machine and came up with the following. Can someone tell me if these are infact the correct parts?
Enermax CS-3051L-B3A (Black) Mid ATX Tower Case Aluminum/Plastic Front Panel w/ Acrylic Cover & Enermax Logo on side Window, Sound Sensitive Neon Light - Retail **Please see images** Specifications: Material: ATX MIDI Tower Case Form Factor: ATX, Pentium 4 M/B Drive Bays: External 4 x 5.25", 2 x 3.5" Internal 4 x 3.5" USB/IO: 2 x USB2.0 + Audio/Mic Case Fans: None (see pics) Power Supply: Powerup 350W P4 Ready Approx. Dimensions: 19" (L) x 8" (W) x 17" (H) Thermalright SLK-800-U ( Heatsink ONLY ). All Copper heat spread. New Version. Dimension: LL87 x W56.4 x H48 (mm) - (Top), without fan. L67 x W81 x H45 (mm) (Bottom), without fan. L25 x W56.4 - Base. Retail. Please see the image. Asus Motherboard for AMD Processors Model A7V600 Retail Specifications: Supported CPU:Socket A for AMD Athlon XP/Athlon / Duron Thoroughbred/ Barton Core Support Chipset:VIA KT600 + VIA VT8237 FSB: 400/333/266/200MHz RAM:3 x 184-pin DIMM PC2100/2700 or 2 x PC 3200 (Max 3GB) IDE: 2 x UltraDMA 133/100 up to 4 devices RAID: 2 x Serial ATA with RAID 0, 1 function Slots:1 x AGP 8X, 6 x PCI, 1 x ASUS Proprietary WIFI Wireless Lan Connector Ports:2xPS2,1xLPT,1xCOM,4xUSB,1xLAN, and Audio Ports Onboard Audio:ADI AD1980 SoundMAX 6-channel Onboard LAN:3Com 3C940 1000 Mbps Ethernet AMD (Microprocessors PC) ONLINE ORDER ONLY - AXDA3000 Athlon XP 3000+ BARTON (~2.16GHz) 512K CACHE w/ QUANTISPEED ARCHITECHTURE - RETAIL BOX Details: AMD XP3000+ BARTON, 512K Cache 333Mhz w/ Heat Sink & Fan - RETAIL Part - CU-122-116 CRUCIAL MICRON 512MB 64x64 PC 3200 DDR RAM - OEM 184-Pin DIMM, CL=3.0 -Unbuffered Non Parity 2.5V, CT6464Z40B Requires DDR supported Motherboard - Lifetime Warranty. OEM Transcend ATI Radeon 9000 64MB CRT+DVI+TV 4X AGP - RETAIL Specifications: Chipset: RADEON 9000 Memory:64MB DDR Bus:AGP 4X Supports 3D resolutions (32-bit color) up to 2048x1536 Supports ATI TRUFORM, SMARTSHADER, SMOOTHVISION, PIXEL TAPESTRY II, VIDEO IMMERSION II, and HYPER Z II technologies Ports: VGA + DVI + S-video Retail box (see pics for details) Powered By ATI Manufactured by Transcend HITACHI/IBM 120GB 7200RPM 8MB CACHE MODEL# IC35L120AVV207-1, PART# 07N9549 - DRIVE ONLY - OEM ONLY Specifications: Size: 120 Gigabytes Interface: IDE ULTRA ATA100 Seek time: 8.5ms RPM:7200 Cache 8MB OEM(Drive alone) 3 Year Manufacturer Warranty Lite On 52x32x52x Beige Color CDRW Drive LTR-52327S - Retail SMART-BURN avoiding Buffer Under Run error, Automatically adjusting writing strategy & running OPC to provide the best burning quality Specifications: Speed: Writing 52X, Rewriting 32X, Reading: 52X Interface: ATAPI/E-IDE Supported Media: CD, CD-R & CD-RW discs (upto 99 min) Buffer: 2mb Access Time: 80ms (typical) OS Support: 95 / 98 / NT / ME / XP / 2000 I was not able to find the "Panasonic Panaflo L1A 80mm (fan for heatsink)". Where can I find this or what can I substitute it for? Also, What else am I missing to complete this system? Much thanx in advance... - GAPE |
Re: Question(s) about The Allenstein Machine..
Allan? Anybody!???
Quick Question regarding new allenstein machine | tempest18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-02-2004 03:42 PM |
Question About The Allenstein Machine. | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-31-2004 08:20 PM |
An Allenstein Machine Question... | In Search of Answers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-23-2004 02:43 PM |
THE ALLENSTEIN MACHINE....question.... | psus15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2004 01:13 PM |
About The Allenstein Machine... | saltine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-07-2003 11:08 AM |
