Old 10-03-2022, 04:45 PM
A Chapman A Chapman is offline
Default Initial startup hangs on "Loading Plug-Ins: VariFi" M1 Pro 12.3
Hi All,
Just setting up a Macbook Pro 14" M1 Pro (16GB RAM / 1TB storage / 10 core CPU / 14 core GPU) and can't get Pro Tools Studio 2022.9.0 to start reliably.
Initially it would hang while scanning one of my plugins (Softube Tube Delay). Moved all my plugins to the unused folder, and it started fine. Brought all my plugins back and it hangs on "Loading Plug-Ins: VariFi". If I remove VariFi, PT Studio re-creates it on startup and it hangs again.
Things I've tried:
Clean uninstall + Reinstall
Moving plugins to unused folder (as above)
Trashing all prefs etc with PT Prefs
Little bit stumped at this stage - anyone had the same thing? Many thanks!
Old 10-03-2022, 05:56 PM
nednednerb nednednerb is offline
Default Re: Initial startup hangs on "Loading Plug-Ins: VariFi" M1 Pro 12.3
Did you install the right version of plug-in bundle?
Did you migrate your OS and plug-ins?
If you didn't do a fresh install and nothing is fixing weird problems that don't make sense, a fresh install is a good place to start.
When I google "site:duc.avid.com loading plugins varifi" I see lots of random stuff over years with different versions.
Potentially, removing VariFi fixes issue for a second, but maybe it's ANOTHER plug-in that is 3rd party having a conflict when it gets loaded. So when PT auto created the stock plugin as you describe, it might have the 3rd party conflict again. So it seems like VariFi is issue, but it might be the signal of another conflict.
SO, move all the plugins to unused AGAIN, then LOAD Pro-Tools, recreate all stock plug-ins, see if PT loads, if so VariFi is fine. THEN, move plugins back manually in small batches to see when the conflict really happens.
From the sounds of it, you moved all your plugins at once, so that is improper troubleshooting as far as I know. Narrowing down a batch at a time then individually, might reveal something.
___
>> me: nednednerB //
||main gig: editing audio & testing software / 2nd gig: music software tutoring //
||software: Monterey 12.5.1 | PT Studio 2022.10 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB //
||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display //
||automation: SoundFlow | Keyboard Maestro | SteerMouse //
Old 10-03-2022, 06:01 PM
Brand new laptop, no upgrade to OS.
It's not VariFi - if I remove *all* third party plugins, it starts. If I bring any third party plugins back, it hangs during the Loading Plug-Ins phase, seemingly on a random one each time I change which plugins are present in the folder.
Old 10-03-2022, 11:40 PM
Where did you get the installers for ALL those plug-ins?
If they are not verified by the developer to work on new Silicon processors, very high probability of problems.
So isolate if ANY of the third party plug-ins work, attempt to update the rest, or uninstall them for now, because they aren't working as you can see PT not loading right unless you remove all of them.
___
>> me: nednednerB //
Old 10-04-2022, 12:29 AM
npapaleo npapaleo is offline
This is a bug for those of use with quite a few plug-ins. Every once in awhile with a fresh install or PT update you'll hang on a seemingly random plug-in during launch. The fix is to remove all plug-ins and add them back in just a handful at a time. I usually ad 30-40 plugs back in, relaunch pro tools, quit PT, add another 30-40 plugs, relaunch, etc. etc. The nice thing is you should only have to go through this whole process once.
Fingers crossed this solution works for you.
Old 10-16-2022, 07:51 AM
685 685 is offline
Yep! This is the solution that worked for me as well. Weird deal but it works.
System info
https://duc.avid.com/member.php?u=57185
"please stop OVERcomplicating simple things"
Pro Tools 12 hangs on "initializing database" when loading shill1970 Pro Tools 12 11 08-21-2017 11:16 AM
Pro Tools Startup Hangs on "Initializing Databases" Tomcom403 Windows 19 11-07-2016 05:48 PM
Pro Tools 11 hangs up at "loading midi engine" step for 10 minutes kevinjrowe macOS 0 08-23-2014 01:25 PM
PT 10 stops loading at "VariFi.aaxplugin" Soul El Windows 55 02-24-2013 09:55 PM
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" georgelegeriii Pro Tools TDM Systems (Mac) 0 11-19-2012 01:14 PM
