Old 10-03-2022, 06:11 PM
take77 take77 is online now
Default Re: 2022.9 and Waves broken
I have V12-14 and one V11 bundle I'll try out on my Windows system tonight.
Particularly, the V11 bundle.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 21H1|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Studio Drummer|Guitar Rig 6 Pro|Hybrid Keys
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 10-03-2022, 06:28 PM
MEIStudio MEIStudio is offline
I just bit the bullet and updated the plugs i have. Sad part is i could have bought new licenses for cheaper to cover the 2 plugins i actually still use of theirs for cheaper than the update plan... going to start modding my work flow to get away from using them. Too annoying.
Old 10-03-2022, 08:34 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by devs1980 View Post
Anybody else having problems with Waves plugins not working properly? Some of my old Waves plugins keep crashing it, not a problem I'd encountered with the previous version
No problems here so far with v13.
MSI Pro Z690-A | i712700k @ 5.1GHz | 64GB DDR4 | 8TB NVMe /14TB WD Black | Audient iD14 | PT 2022.7 | Win 11 Pro | Tons of VIs and plugins
Old 10-03-2022, 09:21 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Originally Posted by MEIStudio View Post
Same issue here. Updated to 2022.9 and something is wrong across all versions of the Waves plugs. Granted mine are long in the tooth. I'm currently running v9, 10, and 11 plugins.
Strangely, the v11 plugins crash protools instantly, whereas the v9 and v10 plugins just have UI issues with higher resolution screens. (they appear small in the corner of the plugin window on higher resolutions and the controls are where they should be on the full window if that makes sense... so a knob thats supposed to be in the middle is still in the middle of the screen, but the GUI is a tiny little thing in the corner). If i move the plugin window to a monitor with a lower resolution, its fine.
I am on Win 10Pro and have not found issues even with V9 plugins so far with 2022.9. Anyone who is having issues can you post which plugin and version you are having issues with, as well as a description of the issue with screenshot if needed? I will then test on my systems any plugin that I have(I think -have ~ 70-80% of their plugins) .
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2022.9 Studio through an A&H Qu-32
Old 10-03-2022, 09:39 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Originally Posted by off the wall View Post
According to the Waves and Avid Compatibility charts, you would need at least Waves V12 to be on a fully supported PT 2022.9 system. That would be running Catalina 10.15.7. Any higher macOS and you need Waves 13 or 14.
V14 is working fine for me on 2022.9.
  #16
Old 10-04-2022, 12:25 AM
npapaleo npapaleo is offline
On second thought, after doing some actual testing it seems the only plug-in I'm having issues with is Reel ADT. Not sure if anyone else has this plug-in and can give it a test. All my other Waves plug-ins appear to be working properly . I tested on Logic, Reaper, and Soundminer and all VST3 & AU versions worked without issue. So it appears to be a PT version issue. I've uninstalled and re-installed and verified that I'm using the most current version.
  #17
Old 10-04-2022, 12:37 AM
JFreak's Avatar
JFreak JFreak is offline
Except that with Waves, things are not that straight-forward. They only have one plugin code (shared among different platforms), and every host runs a WavesHell wrapper. As you can understand anything can go wrong right there, but a new wrapper version may fix it (and break something else).
Janne
  #18
Old 10-04-2022, 08:17 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Wow, Waves really broke some hearts.
V-14 not supported but working well
5,1 Mac metal Mojave.
Ps V8 iLok still works on vintage G5 TDM system
  #19
Old 10-04-2022, 08:42 AM
TOM@METRO's Avatar
I uninstalled all of my Waves stuff. Problem solved.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2022 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #20
Old 10-04-2022, 09:45 AM
JFreak's Avatar
I have V7 ilok attached to my TDM rig with a security cable. That version of Mercury + Studio Classics works with G5's to Intelsand latest TDM release. All the Waves I will (probably) ever need, and once that rig breaks beyond reasonable fixing cost it is goodbye Waves forever.
Unless they change their policy and support HDX, that is. I made a promise to myself not to re-wup until that happens, but also promise to Waves that I will do it once they start supporting "every major platform" as they advertised.
(My A-list of plugins are the ones working on S6L and now that Apple forced the native issue once again, I could not care less which B-list plugins cannot make it into Apple Silicon world. Good riddance, just like Waves.)
Janne
AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9 anearforgear Pro Tools 17 11-11-2022 09:35 AM
Custom Shuttle Lock Speed broken in 2022.5 [PT-290238] ArchStanton Pro Tools 31 10-26-2022 11:38 AM
Duy plugins gui broken in 2022.9 ejsongs Pro Tools 1 10-03-2022 01:39 AM
Looping regions (Audio and MIDI) broken in 2022.6? XJENSEN Pro Tools 3 07-12-2022 11:26 AM
Is the MIDI zoom on the edit window broken in 2022.05 Windows? snowplaysmusic Pro Tools 1 06-17-2022 07:44 PM
