Trouble bouncing to disk, please help
I am using a Mac with Mix plus, 5.1.1 and am having a hard time bouncing mixes to disk. I am recieving an error message type 2, and am instructed to save my work and restart the computer. Now I have tried increasing the memory to Pro Tools but it does not seem to help. The problem is also random. Some bounces work, others do not. Any ideas?
Thanks, Lance |
Re: Trouble bouncing to disk, please help
Hey Lance - You may have tried all this, but… To clear the CPU's brain, throw away Digisetup & DAE prefs (NOT DAE folder!!), then restart. You'll have to re-select your hardware setup (it'll prompt you at PT launch) and PT will take a moment to re-learn your installed plug-ins on first PT launch. ALSO, increase memory allocation to DAE, because more plug-ins require more DAE horsepower.
Then: 1. Make sure DAE buffer is set to "2"; 2. Close all plug-in windows before bouncing; 3. Select "convert AFTER bounce" (not during) ; 4. If possible, bounce to a different drive than the startup drive OR the drive the session is on. Good luck. Warmest Regards, Brian |
Before you trash preferences etc. I suggest you search this forum for "bounce" in the last 10 days : there has been some threads that might relate to your case.
Mark |
Have you got a power mac i.e. 9600 with a g3/4 upgrade card. I had the same problems a few months back and eventually tracked it down to a Newer tech g4 card. Every thing else in PT worked but bounce to disk was hopless. Put back the original Apple 350 card in a 9600 and now all is well ,(apart from having to make the tea while it boots up....slowly)
Other problem could be your card slot order... Ray P |
Another thing is, what SCSI card are you using? I've had this problem with Adeptec cards and after switching to Atto (Digi reccomended) it worked fine. Good luck!!
Trouble Bouncing to Disk with Mp3 file format | kurkomat | Pro Tools M-Powered (Win) | 2 | 01-09-2007 11:08 AM |
trouble bouncing to disk on my mbox | timusic7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-09-2005 12:45 PM |
Trouble bouncing to disk | stickytapenrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-13-2004 08:11 AM |
bouncing to disk trouble | coreybox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-14-2004 08:14 PM |
trouble with bouncing to disk | Dalo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-08-2004 08:49 PM |
