Splitting Gtr signal with Mackie 1604 mixer
Greetings, Trying to find a path by which to split my Fender Strat signal using a Mackie 1604 Mixer to provide a DI output to go into my PT LE and also have an output to go into the Gtr amp for micing. Can this be done with the 1604 mixer?
Re: Splitting Gtr signal with Mackie 1604 mixer
You could plug the guitar into, say channel 1 on the mackie. Output channel 1 to sub mix 1 which would go to your digidesign interface. Then you would connect aux send 1 to your guitar amp input. Use the send knob on channel 1, to send the amount of signal to the guitar amp. Then put a mic in front of the amp and connect it to the 1604 channel 2. Output that channel to submix 2 and record 2 tracks into pro tools and the same time.
Or, connect the guitar to the amp, normal playing style. Put a mic in front of the amp connected to channel 1. If the amp has a line output, that line could go to channel 2 of the mixer. Both channel 1 and 2 could be routed to the sub mix out into your digi interface. |
you could use the busses on the board
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Many thanks for the "time saving advice!"
My mackie 1202 has insert jacks on the channels. Not everybody knows that these can be used as direct outputs, just insert the jack half-way in.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Mackie 1604-VLZ Pro | LC13 | Tips & Tricks | 2 | 08-11-2005 08:39 PM |
Mackie 1604 VLZ Pro | toofly4asoundguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-05-2004 10:19 PM |
digimax LT vs. Mackie 1604 VLZ pro | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-11-2002 12:25 AM |
How do I best use my Mackie 1604 VLZ pro mixer? | pickin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-01-2002 06:56 PM |
Keep my Mackie 1604 or..... | toecat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-06-2000 07:14 PM |
