ATA controller card blues
Hello,
I am having troubles with my Sonnet/Tempo Ultra ATA controller card. When I try to record or playback audio on a drive connected to the card I get DAE -9073 errors. I also get DAE -6045 errors sometimes when I'm not even using the drive on that card. I am considering buying a firewire case and moving the drive external and just selling the ATA card. Any help would be great, Chad [img]images/icons/cool.gif[/img]
Home Studio Setup: PT 9.0.5 Mac OSX 10.7.2 iMac 27" 3.4 GHZ 8 Core i7 8 gigs of ram 003 Factory Chad Evans Chief Engineer Gaither Studios Owner/Operator Big Mix Productions |
Re: ATA controller card blues
Try this....
1) Change the pci slot you have it in. 2) check http://www.sonnettech.com/downloads/default.ht ml To see if they have an update to your drivers 3) Search for the errors you had, example "DAE 9003 error" in the "search the DUC" area. It may tell you what the errors are. 4) I don't know what CPU you have, but I have a G4/400 with a ProMax ATA 66 controller card. I have three drives on it, and another on my "master" drive set to "slave". I use the controller card HD's for video editing, and the slave drive on my main drive for audio. The logic here is that you are not using the PCI bus for digi 001 and controller card... HOPE THIS HELPS [img]images/icons/grin.gif[/img] |
Thanks Kris, I'll give it a try!
I've benn using the sonnet ata 100 card for a couple of months now with great results (knock wood)
The only problem is a bus error on startup once and a while,but the audio is very stable. |
Need help with graphics card/controller | DJohanssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-14-2010 06:23 PM |
OT: IDE controller card recommendations?? | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-26-2005 11:33 AM |
SCSI Controller blues. . . | Hsk | Pro Tools TDM Systems (Mac) | 4 | 10-11-2001 08:26 AM |
Promise ATA 100 Controller Card or No? | Morningstar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-26-2001 07:25 AM |
SCSI card blues? | shift | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-18-2000 11:44 AM |
