#651
Re: New "Mac Studio" from Apple
I see those pesky spikes from time to time and often find the fix in a plugin update, or trashing PT Prefs and creating a new file, or (I know this is an old fix that some will argue with but it's still effective, occasionally, in my studio) zapping the NVRAM.
#652
From what I've read, nvram is reset at startup with m1 macs.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
#653
I have tried a ton of things prior to contacting Avid and Sonnet then I ended up retrying all their recommendations(most of them I had already tried). After doing a complete SSD reformat and reinstall of Monterey I figured the issue might be a little deeper than I could troubleshoot. Monterey, Protools, the HD driver, and iLok was the only software installed but the issue was still happening. I do remember getting one Digi-link License missing error a while ago but it was installed and activated on my iLok3. That error never popped up since but the CPU spikes started around that time. The only thing that seems to resolves my issue is to use another playback device other than the HD Native card. I did not have another thunderbolt device with a 2nd port to try the work-around that was mentioned in another thread. Basically connect another TB device in between the Mac Studio and the Echo III.
https://duc.avid.com/showpost.php?p=...8&postcount=25 Yep!
. System info https://duc.avid.com/member.php?u=57185 "please stop OVER-complicating simple things" |
#654
Maybe one of the clearer write ups on NVRAM and SMC on the Apple silicon Macs is here: https://macexpertguide.com/how-to-reset-nvram-and-smc/ I hope these changes really do help avoid NVRAM corruption causing problems. |
#655
That might be key to the issue. Hardware communication. Did you mention it to Avid?
#656
Good to know. It does seem like a silly thing to deal with after all these decades.
#657
I did mention it and that error was on 2021.12 and happened only once. It's still a bit weird to me because it's the first time I've seen that one in the 6 or so years I've used the license. And I have also been to several different studios in that time frame. With 2022.4 the license is now included inside the Protools software. The CPU spike happens on both versions of Protools though. I was actually surprised that they "qualified" the Mac Studio so quickly and I don't mean that in a bad way. I just figured that they would do maybe 2 months or so of testing before hand.
#658
I gave it a try. With one aux send enabled on all tracks, the PT CPU Total meter fluctuated between 25-28%. Each aux send that I enabled increased the total CPU use. 2 = 35-39%, 3 = 47-50%, 4 = 55-60%, 5 = 64-71%, 6 = 70-76%, 7 = 75-84%, and 8 = 81-86%. It still played back for me with nine of the aux sends enabled on all tracks, with the PT CPU Total meter fluctuating between 87-96%. When I tried playing back with all ten aux sends enabled, it instantly gave me an AAE 9173 (ran out of CPU) error. Very interesting and illuminating test. Thanks for setting it up! Quote:
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
#659
A couple more notes. I was running the test with a 32 sample buffer setting. I am currently running macOS 12.3.1 and PT Ultimate 2022.4 on my 32GB/1TB M1 Max Mac Studio. I ran the session from the system drive.
While I did refer to the PT CPU meter in my previous post, I also monitored the CPU use with iStatistica Pro and Activity Monitor, and did not see any significant differences in the CPU use being reported by any of them.
#660
I managed to get all the plugins I was using on a recent project (5.1 music mix) installed on Pro Tools 2022.4 on my new Mac Studio Ultimate (20c cpu, 48c gpu, 64GB ram, 1TB disk). I build kind of a super template when I mix each score which contains my bussing and auxes and most all of the composer's tracks I have seen on any cue, so next time the same track appears in a later cue, I have something to match it to in this template.
It's 48k with a lot of routing some aux sends and some channels with chains of a few plugins. I run a core-audio interface at 1024 buffer. Old computer is Catalina, new obviously Monterey. Old computer was PT 2021.12. This template made the Pro Tools CPU overall meters sit at about 79% on my 10-core 2013 Mac Pro (yes, Frankenstein CPU mod which as you would expect performs right in between the 8-core and 12-core. On the new Mac Studio about 42%. I have yet to install Eucon on the new machine, but it was just parked so don't think that would make any difference. More to come, maybe, but seems fairly promising. |
Complete Recording Studio FOR SALE! Pro Toold Hd2 Accel, C24, Apple, Mogami, etc... | sketchellis | Buy & Sell | 15 | 05-06-2013 06:27 PM |
apple-m "mute region" clash with finder apple-m "minimize" | wez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-12-2007 05:19 AM |
2 Power-Mac's on 1 Apple Studio Display? | Optimus Prime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2004 01:11 PM |
Has anyone had this problem with their Apple Studio Display? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-29-2002 12:55 AM |
Please advise on best setting on Apple Studio Display LCD Flatscreens - going blind! | Jules | Pro Tools TDM Systems (Mac) | 5 | 05-05-2001 12:54 AM |
