Clip lag with drag and drop from clip list in PT 12.5
Hi there,
I'm having an issue where dragging and dropping clips from the clip list onto audio tracks is resulting in a delay as I try to tow my clip to the desired place on the timeline. The session I'm working within is several months old and this issue has only come about since brining the session back from a mix facility. This issue seems to be on my rig only - other people in the crew can open the same session without the lag on drag and drop. The system I'm using is HDX with El Capitan. If anyone has an idea as to what might be causing this - that would be great! Cheers, Rowan
PT 2021.12.0 HD Native with Omni, MacPro 2019 3.2 GHz 16-Core Intel Xeon W, 96GB, OS 11.6.4 |
How do you drag a clip and make it snap precisely to the clip to its left without it | maxgain | macOS | 8 | 03-13-2018 09:55 PM |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | AAX Plug-ins | 2 | 06-21-2017 11:29 AM |
Sorting clip list by clip start in session? | levelaudio | Pro Tools 11 | 1 | 10-14-2016 03:09 PM |
D Command drag clip talkback issue | kptkarl | Post - Surround - Video | 0 | 07-24-2012 02:16 PM |
drag n drop trans to reg list | redchair | Virtual Instruments | 3 | 12-14-2010 06:17 PM |
