Folder Tracks--unwanted vertical scrolling
Does anyone know a way to stop the unwanted "scroll to selected track" that happens when opening and closing folder tracks? Super annoying. If I happen to have a track selected above or below where I'm currently scrolled in a session and I open or close a folder track, the session scrolls to that selected track, which I don't want. I can stop this by selecting the folder track I'm about to open or close, but this is a pain if I forget to do that. I just don't want that auto scrolling at all.
Re: Folder Tracks--unwanted vertical scrolling
It seems to be an interaction between the settings in the control app "App Banks Daw", "Auto-Bank to Selected Track" and Pro Tools preference "Edit Window Follows Bank Selection" but I get weird results and I can't make unwanted scrolling go away unless I turn off "Edit Window Follows Bank Selection". But I don't want that off. I just don't want to scroll to the selected track every time I open or close a folder track.
It's as though opening or closing a FT constitutes a "banking event" and triggers all this other stuff. But this functionality implementation is obnoxious. |
Hi, welcome to the community.
Have you read the Help Us Help You page linked in the forum header? Before anyone can help you we need to know your system.
Did you find a solution to this annoying issue?
I experience this as well and it drives me a little bonkers.
Preferences > Mix > Controllers section in Pro Tools
Disable what you don't want
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Which option do I disable to stop banking the edit window only when closing/opening folders?
"Banking" is specifically for control surfaces (a bank being a set number of faders.) Is that what you mean? Do you mean something is scrolling to the top on Pro Tools? When opening/closing folders from where? A control surface? Clicking on the folder icon or use the keyboard shortcut to open the folder in Pro Tools? By default, Pro Tools (when you click on a folder) it spills/opens it downward on the edit window. It does not change the position of the tracks above the folder track.
Better yet, make a quicktime video of the behaviour and post a link to it here (open quicktime, and choose record screen and then do what is annoying you; don't do it from a phone camera because you can rarely see things well on a screen)
I'll try to make a video when I have time. I'm working to a deadline right now. (So naturally here I am gabbing about non-work)
Basically, if my surfaces are banked to one point in the session but I scroll to another point in the Edit window and toggle a folder track Open/Closed then it will scroll the banked tracks back into view in the Edit Window. Eg. I have all of my stem busses and print tracks in Basic Folders at the bottom of my template. EUCON is banked to a audio tracks way up the session. I scroll down to the bottom of the edit session to look at something, then toggle a folder and suddenly I'm looking at the banked tracks again. |
Vertical Scrolling...How do you do it on the touchstrip? | firmflange | Avid S1, S3, Dock and Control App | 3 | 10-09-2020 07:49 AM |
Tracks Auto Record-Arming and Weird Vertical Auto-Scrolling | CarterFischer | Pro Tools 2018 | 2 | 02-18-2019 03:16 PM |
Vertical Scrolling Increments | dulla | Pro Tools 9 | 0 | 07-30-2012 08:41 AM |
Pt auto vertical scrolling | renec | Pro Tools TDM Systems (Mac) | 5 | 02-28-2011 12:20 PM |
Scrolling Vertical/Horisontal | GS-DK | Pro Tools TDM Systems (Mac) | 8 | 11-08-2010 03:29 PM |
