Old 03-05-2025, 06:39 AM
clipGain clipGain is offline
Default Creating track preset on Master fader -> crash
Starting a new project, importing an audio file to have some audio. Creating a stereo Master fader track. All good, playback OK. Inserting a PT EQ for example on the Master fader track, and then trying to create a track preset makes PT crash completely every time I try.
Old 03-05-2025, 09:50 AM
tope d's Avatar
tope d tope d is offline
Default Re: Creating track preset on Master fader -> crash
We'll need more info from your computer's specs. RAM? Processor? Operating System and OS version? System Type?
Thanks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-05-2025, 10:14 AM
Hi there,
Mac M2 Studio, Sequoia 15.3.1, 32 GB RAM, Pro Tools Ultimate trial
Old 03-20-2025, 05:51 AM
Am I the only one with this configuration experiencing this?
Old 03-20-2025, 09:37 AM
And does Pro Tools crash with an error, or message in the log file?
Old 03-20-2025, 10:02 AM
tope d's Avatar
Originally Posted by clipGain View Post
Hi there,
If you can try rolling back to 15.2, this might help since this is the supported OS version. https://avidtech.my.salesforce-sites...tibility-Chart
-Tope
www.topedomingo.com
Old 03-21-2025, 12:52 AM
Yes, I usually report the crash logs to Avid.
Thanks I was not aware of that specific chart.
Old 03-21-2025, 02:19 AM
That is not what I asked, and doing that is unlikely to help you.
What *exact* error if any do you see on the screen? Or if no error on the screen what error is in the log file (~/Library/Logs/Avid/Pro_Tools_*.txt)? or if you can't make sense of those cyptic files maybe just give the last dozen lines or so, or even better post the file on a file sharing site and put the link here.
You say *Project*, which has specific meaning in Pro Tools, I really hope you really mean a *Session* not a Project. Pro Tools Cloud Projects are buggy and unreliable I would never try to use them. In contrast Pro Tools Sessions are saved on local disk and you should be using those. If you are using a session what type of drive/filesystem is the session save on? If you have been using a Cloud Project, give up now and work with Sessions.
Have you tried any standard troubleshooting? Trashed prefs? (use Pete Gates' free PT Prefs2 utility). Tried running after moving all .aaxplugin files from the plugin directory? (Pro Tools will automagically put back core plugins) just test with those. etc.
Rolling back Sequoia is likely a waste of time. Many of us are running on all different version of Sequoia including folks like me who have been running on the latest betas without any problems (well one Apple bug that briefly broke iLok in a beta but has been fixed). Sequoia and the latest versions of Pro Tools has been a relatively stable combination.
Old 03-21-2025, 10:20 AM
Yes I meant session (project in Logic lingo), thanks.
I can not find an Avid folder in the Logs directory, nor any log files elsewhere.
I have trashed prefs previously, and will do a systematic plugin scrutiny after I deliver my current project (!).
Freq Change When Creating Track to Master ts1234 Pro Tools 2020 4 02-09-2021 09:07 AM
Creating a Fade Out on the Master Fader? Rick Akoni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 11-03-2006 09:55 PM
Creating a midi track crash Ozzie Pro Tools TDM Systems (Mac) 2 06-29-2005 01:06 PM
Creating Master Fader SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 06-19-2004 06:00 AM
creating a master fader Ryan H. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2001 12:41 AM
