Old 03-04-2025, 01:35 PM
ishur ishur is offline
Default Remote transport control with D-Command?
So, I have replaced my ancient HD2 system with a new Mac Studio and an HDX card, and upgraded to the latest PT version. I'm running it under Rosetta, and the D-Command works perfectly. However, I used to use an ancient Frontier Design TranzPort for remote control. It was a simple little wireless controller (just buttons, no faders) that worked perfectly...but there aren't any modern drivers for it.
It appears, after research and experimenting, that you can't run Eucon and the legacy D-Command at the same time, so Avid Control on an iPad isn't an option. I tried, and I could only have one of the two (iPad or D-Command) active at a time. So, is there a simple software or hardware solution using HUI (preferably wireless) that could be used?
Anyone out there using an Icon with current PT with some way to remotely control the transport?
Old 03-04-2025, 05:13 PM
smurfyou smurfyou is offline
Default Re: Remote transport control with D-Command?
The Tranzport was unique because it used it's own transmitter/receiver. I can't think of a current HUI hardware controller that is wireless.
There have been one or two available on the IOS app store over the years but they usually get abandoned.
I used to use one on Android called TouchDAW. It might still be available. Does require a little bit of setup but after that worked well.
~Will
Old 03-04-2025, 05:22 PM
Oh I just looked and Korg claims their nanoKontrol Studio works on modern Macs... might be worth a look.
~Will
Old 03-04-2025, 07:29 PM
Thanks. It does appear it might work. Overkill for my purposes, but that's OK. Too bad there's no screen. I already miss my TranzPort. :-(
I did try several of the iOS apps (Pro Transport, MIDIQuest, etc.) with my iPad, couldn't get any of them to work...
Old 03-05-2025, 03:39 AM
henningaround henningaround is offline
You could try to use a Stream Deck with the MIDI-Plug-In. I use it for a lot of functions that HUI is capable of. Only thing is you have to dig into raw MIDI a bit.
Old 03-05-2025, 06:19 AM
Well, I'm not a MIDI expert but maybe I could figure it out. One downside is that it's USB powered, so not as portable. Still, looks like a possibility.
Old 03-05-2025, 06:48 AM
I think Elgato also released a Steam Deck App for Android and iOS. Maybe it's worth having a look at it.
Old 03-05-2025, 07:18 AM
Yes, I will. Thanks.
Old 03-06-2025, 12:30 PM
The Avid Control app on an iPad is worth a look(and its good for lots more than just remote control)
Old 03-06-2025, 01:22 PM
You cannot have D-Command and EuCon at the same time.
D-Control/Command Remote Control of Carbon or Carbon-Pre Mic Gain bigbuddy3 Pro Tools | Carbon 2 01-15-2025 05:50 AM
Has anyone had any luck using remote desk top to remote control PT? Fullsound Recording Pro Tools TDM Systems (Win) 1 10-14-2008 03:44 PM
Command+control+P for dynamic transport is wrong! crizdee Pro Tools TDM Systems (Mac) 0 12-11-2006 10:24 AM
Remote control of Pro Tools transport David MacNeill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-09-2005 07:31 PM
Remote Transport Control OgnKog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2004 10:47 AM
