Reason does not show up in plug-in list
Hi there,
How do I launch Reason (full version) from Pro Tools LE? Reason Adapted shows up on the Inserts > multi-channel plug-in lists but not my REASON 2.5. Is there a way to browse and tell PT where my Reason is? Thanks very much, Chuck |
Re: Reason does not show up in plug-in list
if you have 2 versions of reason installed on your machine, you may have a conflict.
I'd uninstall both versions, look for any files, or directories not cleaned by the uninstallers in Program Files, and delete them. Then, I'd go to C:\Program Files\Common Files\Digidesign\DAE\DAE Prefs And delete the contents of this folder. Then... Re-Install Reason 2.5 Full Open, authorize reason, insert the Orchester, and factory soundbanks when and if prompted, make sure it's running and authorized. Re-Boot. Open up pro-tools, and see if that helped.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
thanks- i'll give that a try!
it might take me a while to dig up my old Reason disks but i'll do it. I was worried that Reason Full wouldn't be compatible or something. i'll let you know if it works! |
thanks a lot- that did the trick.
PEACE OUT |
Please help- PTMP 8 doesn't show LIVE in plug in list | Tool99 | Pro Tools M-Powered (Win) | 0 | 08-22-2009 10:37 PM |
Reason Adapted doesn't show up as PT plug-in | DBR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-17-2008 12:55 AM |
Reason Doesn't Show In Plug In's | alanbrockman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-28-2007 08:23 PM |
Reason/Rewire does not show up in plugin list | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-16-2007 08:33 PM |
Reason not available in plug in list | bigboi78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-27-2006 03:40 AM |
