Show/HideTrack list bug 6.7
I've had a small problem with the Show/Hide track list ever since I upgraded to 6.7. I have the latest cs releases and it still hasn't been fixed. I have to click several times on a track before I can show or hide it. Sometimes it works, sometimes it doesn't. Also, some times if I click on a track it will hide all the other tracks and keep that one showing. The same as if I did option-click. Anyone else notice this. It happens in any session I make, but it is somewhat inconsistant. At times it works just like it used to, but most the time it's very frustrating. Anyone else experience this?
Re: Show/HideTrack list bug 6.7
I haven't been able to reproduce that problem, but if I do run into it, I will post back (6.7cs8)
Not sure but I think the problem might be my (Apple)bluetooth mouse. It seems like now if want to select/deselect a track I have to click very quickly or it will turn into the dotted line to move the track and not select it. Almost as if the mouse response time is a bit slower so if I click at the normal speed it thinks I'm going to click and drag. I've changed my mouse settings but it doesn't seem to help. I plugged in a USB mouse and it seemed more like a remember it. Anyone else with a Bluetooth mouse have this problem?
Chris,
I reported this (or a similar) problem shortly after upgrading to 6.7. What I've discovered is if you click on the little symbol (triangle, circle, etc.) by the track name, ALL tracks will be deselected except the one you click on. Kind of like holding the ALT key down. Also, to draw a marquee around a bunch of tracks to select them all, it seems you need to start on the left-hand side, selecting over the little colour bar beside the symbol. Very easy to accidentally click the symbol. I'm not sure if this is supposed to be a feature, or just a low priority bug, but it certainly bugs me at times. Ray |
Eleven Le does not show up in plugins list | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-19-2009 06:02 AM |
Reason/Rewire does not show up in plugin list | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-16-2007 08:33 PM |
plugins don't show up in insert list (7.1.1) | deluxe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-13-2006 04:35 AM |
Xpand does not show up in the list | attilaworx | Virtual Instruments | 1 | 11-28-2006 12:24 PM |
Reason does not show up in plug-in list | chucke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-05-2005 10:10 PM |
