Add This Feature please !!!!!
Dear Digidesign,
This feature should be so easy to implement. Pro Tools Audio tracks let you monitor the track or the input when you're in record ready. I want you to add the feature that lets you keep it in input even if it's not in record ready. We could call it input only mode and it would make the record button yellow instead of red. Analog tape machines always had this feature and it would make productivity quicker for inputs (MPC, Reason, XV3080, Synths) that will eventually be recorded. The workarounds now are to: 1. Use an Aux input 2. Leave the track in record The problem with #1 is if you want to print it later, you have to make an audio track, match all the plugins & automation and sends first. Not good with 32 tracks of inputs. The problem with #2 is if you want to record anything else, (Vocals, Ac Gut) now your inputs all get recorded. They may not be finished yet. I guess you could record them now. Take them out of record, and rerecord them later. Also a PITA. This feature is pretty basic and can really help our Work Flow. There is another workaround which would also be easy to implement. Make a menu choice "Turn Aux Input Into Audio Track" This would give you the ability to solve this problem another way. Thanks for your consideration. (Don't forget NEW TRACK TEMPLATES)
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
Re: Add This Feature please !!!!!
I 2nd that
Agreed!!!!!!
Great idea....that ability is sorely missed in PT.
When it's perfect, there'll always be another change! |
HONK!
It could be even easier. Why not have a "convert aux input to analog track command". I would think that would be even easier to do.
Steve
Steve Shepherd Extreme Mixing |
Yeah
and I'd like the midi channels to do a similar thing. |
I'm wondering if the reason they don't employ our ideas is because of law suits.
So I, Produceher, (being of sound mind and body) give this idea to you, Digidesign, and hereby forego any and all profits that could or will be collected as a result. If you would like me to call my lawyer let me know. I encourage [Benjamin] to do the same so that we can have these 2 ideas. Thanks guys.
The DUC is the secret brainstorm room in the Digi R&D building!
While you’re at it please add Shuffle in both directions. [img]images/icons/grin.gif[/img] >>><<< [img]images/icons/grin.gif[/img] |
Here's another idea - a "render" function that would print a track (with its plugins) without having to set up a bus to another track. Ideally, this would create a new track, print the audio, and then deactivate the original track in case you wanted to go back and make adjustments.
I'd love to be able to speed up this process, as I often print my Ampfarm, Sansamp and Virus tracks to free up DSP. I, mdvirtual, being of sound mind and body, give this idea to you, Digidesign, and hereby forego any and all profits that could or will be collected as a result. [img]images/icons/rolleyes.gif[/img]
Michael Damon Composer/Sound Designer Virtual Productions PT Ultimate, i9-9900k, 64GB RAM, Gigabyte Aorus Ultra MB, Sapphire Radeon RX580, Windows 10 Pro, Fireface UFX |
Bug or feature (10.3) | Frank Kruse | Post - Surround - Video | 6 | 10-17-2012 02:06 AM |
PT8 feature or bug? | poly915 | Pro Tools TDM Systems (Mac) | 1 | 10-29-2010 02:01 PM |
Is this a bug or feature in PT8? | laki | Pro Tools TDM Systems (Mac) | 1 | 04-11-2009 05:37 AM |
Is this a bug or a feature?! | mannikin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-27-2005 04:36 PM |
Is this "feature" gone with 5.0? | Przemek | Pro Tools TDM Systems (Mac) | 5 | 11-05-1999 07:46 PM |
