Ribbon mics -> splitting -> 48V
If I were to use a regular splitter cable from a BLUE Woodpecker figure-8 ribbon mic as part of M/S recording - how does that work? Phantom power on both preamps?
Re: Ribbon mics -> splitting -> 48V
I would use 1 preamp and use the splitter after the preamp, much easier than trying to get gain matched between two pres
but no, phantom from 1 pre only
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Good suggestion. Thanks!
Or record the signal to a mono track and split it out in mixdown(sounds exactly the same). When I do this, I usually just monitor the cardioid during tracking. You can also run the mono audio track and AUX send it to a mono AUX track with a polarity reverse inserted(the 1 band EQ works fine for this).
Thanks.
Has anyone ever used Cascade Ribbon Mics? | Chris Richmond | Tips & Tricks | 0 | 02-09-2007 06:18 AM |
AEA ribbon mics! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-17-2006 10:15 AM |
Beyer M500 Ribbon mics, re-ribbon? | BAJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-14-2004 04:43 PM |
An advice on ribbon mics | ISedlacek | Tips & Tricks | 11 | 07-16-2003 09:54 PM |
Royer Ribbon Mics | juneaudio | Tips & Tricks | 16 | 09-10-2000 10:12 PM |
