Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 10-28-2021, 04:25 AM
Fuzzyc Fuzzyc is offline
Default Export Tracks, retaining track names
I looked around the forum but wasn't able to find a clear answer to my question. Sorry if I overlooked it somewhere.
I need to export a large session while retaining the track names. I only need to send the processed audio files. When I export the individual wav files, I loose the track names. Each track takes on a name starting with the session name followed by a string of characters (i.e. "Traveling LbdrqMYPZfpwqVBBB"). I need for the person receiving the files to know which track is the bass gt, lead vocal, kick drum, etc.
Any help here would be much appreciated!
Thanks,
Fuzzyc
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2021
Focal CMS 65 Monitors
Avantones
Old 10-28-2021, 05:06 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Export Tracks, retaining track names
Not sure I understand. When I Export the audio on a track, I name the Clip and when I Export that Clip it retains the name I gave it.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-28-2021, 06:06 PM
This^^^. You need to name the clip(not the track)
Old 10-29-2021, 11:28 AM
The Weed's Avatar
"I only need to send the processed audio files."
Maybe the OP is bouncing the tracks individually to retain the processing and any automation? Which would not happen when exporting if the effects are real-time and there is any automation on the track. But there is a place in the Bounce Dialogue to name the file.
If that's what needs to be done, then "Commit" would be the route to take, then name the resulting Clip and export it.
OMF/AAF export/import - track names Mringlesworth Post - Surround - Video 0 06-19-2014 11:44 AM
Track names vs Playlist names bredo Pro Tools 10 6 01-07-2013 09:29 AM
How to export track names in a text file? lapieuvre Pro Tools M-Powered (Win) 1 06-29-2010 10:52 AM
MIDI Export not retaining channel info? peterg MIDI 0 04-17-2007 08:42 AM
PT shifting tracks/retaining automation/volume immediatejon Pro Tools TDM Systems (Mac) 2 10-20-2005 07:02 PM
