Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 08-04-2021, 04:49 PM
Default Re: Loss of Playback Engine Mid-Session
Looking at your screen shots again, it's weird that all of the other playback engine options disappear, especially the MacBook Pro Speakers and Microphone and Source Nexus. I think it might be a good idea to start a support ticket.
Scott Gatteño
Old 08-05-2021, 07:37 AM
DEliker DEliker is offline
Now I'm thinking Janne was right. It's sorcery!
Evening session last night was a bust when the problem manifested again.
Sat there for over an hour trying different things with no result. Then, I pulled out the USB-C connection for the external display in my booth. Launched Pro Tools...and all playback options were back.
When on the horn with Avid the previous night, they were having trouble seeing my screen by remote. We were messing around with display settings to try and address it and I think I may have pulled out the display cable. But as we were trying a bunch of different things at once, restarting and reconfiguring the Clarett cable, when we fired up Pro Tools and everything had reappeared, I didn't even consider it was the display line at the time. Thought it was a result of taking the load off the Thunderbolt hub.
So, can't quite say cause and effect just yet but...maybe "wiggle it" was the right answer after all.
That's a USB-C to HDMI connection for the external display in the booth. Allows me to keep the fan noise outside. So it's necessary, but maybe if I can find a cable with a display port end, I could take it directly into the hub.
Could it really be that simple?
Old 08-24-2021, 07:48 AM
Just stopping back to put a button on this conversation.
The issue has only occurred one time since my last report and was quickly resolved. It does seem to be an external monitor/display cable issue.
I'd ordered a new cable for the monitor that was HDMI to display port.
While waiting for it to arrive, I had continued the current setup taking the interface direct to the USB-C port on the computer and running the display into the open USB-C port on the Thunderbolt dock.
This didn't stop the issue from presenting again, but all I did was disconnect the external monitor cable, restart the ProTools app. All the devices showed up again immediately, and I reconnected the cable.
I haven't had any further issues.
So, I guess we can simply confirm:
There is something about external display cables/monitors that seems to cause Pro Tools to lose playback engine options.
SOLUTION: Disconnect the display cable, restart ProTools, press "n" on launch to confirm playback engine options, and reconnect the display.
Calling it SOLVED.
Old 08-24-2021, 08:41 AM
Originally Posted by Obsidian Dragon View Post
Too many devices fighting for your USB/Thunderbolt ports may cause conflicts or provide insufficient power to some devices.
Display monitors do tend to use up quite a lot of thunderbolt bandwidth depending on the resolution (4K or higher especially). I suspect the display monitors also require a significant power draw from the ports that may sage the power to your audio interface, hence the bandwidth or power draw may cause a disconnect of the audio interface from Protools. Even though the audio interface reconnects to MacOS, Protools may not reestablish a connection after a disconnect, thus requiring a restart of Protools.
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.10
Having to Switch Playback Engine EVERY TIME I open a session MattyJones Pro Tools 11 4 11-16-2015 05:21 PM
Having to Switch Playback Engine EVERY TIME I open a session MattyJones Pro Tools 11 0 11-11-2015 10:50 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 12:52 PM
Default Playback Engine on session open bgsoundman Pro Tools 11 2 03-19-2014 09:25 PM
Loss of playback engine samples MarkGOG Pro Tools 9 3 11-12-2010 12:25 PM
