Old 02-22-2010, 12:55 AM
GS-DK GS-DK is offline
Default Midi - first note doesn't play
When I play a midi recording it seems that the first note doesn't play properly. There's a sort of fade in on it (the sound coming out) - after I have triggered the note everything is ok - until next time I start again.
Any solutions?
Thanks for replying!
Old 02-22-2010, 01:14 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Midi - first note doesn't play
Any solutions?
Are you using realtime midi quantize? or have you committed the quantize?
Is the note exactly on the grid?
what's the midi triggering? what type of sound!
No compressors in the monitor path!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-22-2010, 01:24 AM
Thanks for helping!
Quantize has ben committed.
Note is exactly on the grid.
All sounds (first sound) have the same "fade in" - sort of an envelope opening - or the disk has to respond. It doesn't matter if it's instruments in Pro Tools or coming from Logic.
And no compressors in the path - at all.
And btw. I'm doing research right now how to improve midi-timing which is outstanding bad in PT. I just can't get the audio to be on the spot - after recording midi data into audio. I have to manually align the audio afterwards. I have tried routing to aux - removed delay compansation - but it's a boring work afterwards.
Old 02-22-2010, 05:04 AM
systemexclusive systemexclusive is offline
You can use "Beat Detective" to align audio with transients (especially if you record external hardware synth).
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8
mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop
r3, microQ, Albino3, impOSCar, Structure
m1active 520 & sub gw s750, deq230, cx2310
Old 02-22-2010, 06:09 AM
That's another problem..... this problem is the SOUND - sort of no attack on first note. Like a wrong envelope curve.
Why won't PT play back the correct MIDI note lengths? cgoslow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-29-2023 12:59 PM
10.3.5 on a Mac MIDI note play Ty Ford macOS 2 06-20-2013 06:23 PM
Random X on midi note which does not play? duderonomi Pro Tools 9 16 10-30-2011 06:55 PM
MIDI note not recorded at the time I play drums77 MIDI 1 09-12-2010 07:12 PM
strike will not play a midi note on a track Filmusic Virtual Instruments 2 07-30-2010 12:48 AM
