Old 06-29-2005, 09:05 AM
Default Automation Being Written on Untouched Track
I'm using the Command|8 with PT v6.4.1cs3.
Problem: When writing volume automation with channel 1, some automation is being written to channel 2.
Reproducible: Yes.
Steps to Reproduce:
1. Enable auto write/touch/latch on channel 1.
2. Press play.
3. Write volume automation using channel 1.
4. Press stop.
What should happen: Automation should be written on channel 1.
What does happen: Automation is written on channel 1 and some automation is written to channel 2.
Other info: The automation being written to channel 2 does not appear to be correlated in any fashion. Writing automation on channel 2 does not result in automation being written to any other channel.
Has anyone ever observed this behavior? Any suggestions are appreciated.
Old 07-02-2005, 01:57 PM
Dan Pinder Dan Pinder is offline
Default Re: Automation Being Written on Untouched Track
I thought I was the only one.
Here's what I think is happening; there's a grounding problem somewhere or something. If you have your finger touching the metal plate where the numbers are (light gray area) it seems to conduct a bit of finger heat to the adjacent fader #2 at certain times. If you have your index finger on the first fader, then touch the screw below the 2nd fader with another finger on that hand, it activates that fader EVERY TIME and you can see it on the scribble strip. Only with the 1st fader, do I have to conciously raise my wrist off the Command|8. No other faders seem to be affected.
Old 07-02-2005, 05:56 PM
The angle at which I was testing this could not have implicated my wrist touching the Command|8 as the source of the problem. Nevertheless, Mike Z @ Digi set me up with an RMA to get the "jittery fader" mod in hopes that it would fix my problem (our Command|8s were from the pre "jittery fader" mod introduction).
Old 07-12-2005, 08:23 PM
jimlongo's Avatar
jimlongo jimlongo is offline
This started happening to me today. I'm gonna investigate further tomorrow. It seems it's only if the track in question is controlled from the first fader of the C8, then the second track gets written to as well. If you move it to another controller fader it won't affect the next track.
noise | jimlongo
Old 07-12-2005, 08:49 PM
Precisely, but who wants to create a useless track 2, 10, 18, 26, 34, 42, 50, 58, etc.? The place where our Command|8 is at won't have it ready at the earliest until next Wednesday I reckon. I'll let you know if it works when I get it back.
Old 07-13-2005, 11:55 AM
jimlongo's Avatar
I can only get this to happen with a certain number of tracks and under certain conditions. For instance 8 stereo tracks will exhibit this, 8 mono channels won't.
Here is a surefire reproducible case for me. 8 stereo tracks, all in touch mode, then write automation to all tracks
Then write automation to first track and the second will be altered.
At any rate even with just 2 mono tracks writing automation to the first will create breakpoints in the second
BTW that's C8 with 6.9.2cs1
noise | jimlongo
Old 07-13-2005, 07:10 PM
So either this is a bug in the software that has existed since day 1, or a rev G Command|8 fixes the problem. We shall find out in 1 week!
My $ is on the rev G. I haven't had the engineer that caught this report it since, though the Command|8 he's using isn't rev G either...hmmm...
Old 07-13-2005, 08:22 PM
jicamasalad jicamasalad is offline
Thanks to you all for your posts - very informative.
I too am having the exact problem described: touching fader 1 causes fader 2 to "think" it's being touched, although intermittently; sure looks like a grounding issue to me - surface area of my hand touching the metal part of the chassis seems to have some effect - i.e. touching ONLY fader 1, fader 2 seems stable, resting my hand on the Command|8 and touching fader 1, fader 2 has data written.
I'll be contacting Digi tomorrow for an RMA.
Another very helpful session at the User's Conference.
Tonight I sleep not feeling quite so alone!
Thanks again,
Kent
Old 07-15-2005, 06:56 PM
Rev G appears to have done the trick. Thank you Digidesign!
Old 11-18-2005, 04:32 AM
mclf mclf is offline
what do yu mean by rev G ?
Muted track unmutes when I hit play with no automation written? jjboogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-16-2023 08:00 PM
Adjusting volume after automation is written rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2015 06:42 AM
extra automation written viaspiaggia Post - Surround - Video 4 06-14-2013 12:28 PM
Automation won´t work when written with controller Audiophil85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-16-2008 09:14 AM
"No automation could be written.... dkroger ICON & C|24 4 12-19-2005 08:43 AM
