Old 04-28-2007, 12:13 PM
pukeuv pukeuv is offline
Default How to automate all or all selected tracks?
Hi everyone,
I would like to know if someone has any great tips for these situations:
1. Say you want to mute all tracks either by muting or by automating volume parameter to zero. Is there a way to select mute parameter for all the tracks and write a mute on all tracks with a single command? I realize volume would be a bit different since all tracks probably has different volumes already set. I guess you know what I´m trying to do, is there an easy way?
2. If I have 6 tracks of guitar, recorded line in (original tone from guitar, no amp) and I have Ampfarm inserted on all the tracks with the same setting, if I want to change gain or treble or whatever for ALL the inserted Ampfarms at once, can I do that somehow? This is useful since soloing a track and changing the Ampfarm setting does not represent how all guitar tracks would sound when changing the setting. For example distortion is quite sesitive when you have 6 tracks added together, you don´t need that much distortion to make it sound really distorted if you know what I mean.
Looking forward to your input!
thanx
Pukeuv
Mac PPC dual 2 Ghz, 8 gig ram, PT HD3 accel, PT 7.1 cs10
Old 04-28-2007, 01:05 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: How to automate all or all selected tracks?
Hi everyone,
thanx
Pukeuv
1. Group all your tracks(select the tracks you want in the group and press apple+G) that you want to automate! now all automation will appply to all the tracks in the group! VOLUME/PAN/MUTE etc.
Don't forget you can send all tracks to an aux bus and use the bus to adjust volume/pan/mute etc and of course you can place a plugin on the bus which will effect all the tracks that are bussed to it!
also don't forget to use VCA faders to control groups!
2. i don't think you can't automate multiple instances of plugins together! but you can use copy paste from the plugin pull down menu or simply save the preset and load that into all plugins.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-28-2007, 01:46 PM
Stig Eliassen's Avatar
Actually, you can do this. It's one of the new cool things you can do with groups these days. Just make sure that the plugin is instantiated in the same slot number for all the tracks.
Old 04-28-2007, 02:09 PM
crizdee's Avatar
I tried that and i couldn't get it to work! i thought it was possible?
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-28-2007, 03:27 PM
Let's say you instantiate an eq in insert A on two audio tracks. Group them, and check "Controls" for insert A in this group (Attributes). I always have "Follow globals" unchecked.
Does it work?
Old 04-28-2007, 05:42 PM
Andre Knecht Andre Knecht is offline
Actually, it was already possible (and working) prior to the introduction of 7.2’s new grouping functionality. The difference is that, now (with 7.2 and beyond), grouped plug-in automation has to be enabled explicitly, just as Stig described.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 04-29-2007, 03:03 AM
crizdee's Avatar
Does it work?
Just discovered this is HD only and i'am at home on my LE setup. at home is where i usually look at the new features etc and reserve studio time for getting paid!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-29-2007, 08:18 AM
Really? It's the other way around for me.
How to prevent all tracks from being selected DC-Choppah Pro Tools M-Powered (Win) 11 07-04-2022 08:13 PM
All my tracks are selected (highlighted). How to get rid of this? RiF Getting Started 15 05-16-2013 09:17 PM
can't stop all tracks from being selected aldersyde Pro Tools 10 1 05-30-2012 06:59 AM
Workaround to automate plugin presets on audio tracks ampnerd Pro Tools TDM Systems (Mac) 2 03-06-2009 02:46 PM
cannot group selected tracks? claudeklauss Digidesign Hardware & Software 1 02-10-2001 10:00 AM
