Old 06-22-2013, 11:55 AM
JChance JChance is offline
Default 10.3.6 Problem with "Save Copy In"
Trying to upload a comp'ed session for a mix engineer who's running an earlier version of Pro Tools.
For some reason, I can't save a copy without it automatically forcing me to copy (duplicate) the audio files.
No reason to spend that extra time to upload and burn the hard drive space, as I simply want the session saved in a 7-9 format. All audio matches (24/48 bwf), so it's not a conversion issue.
Any ideas on how I can get those checkmarks "un-gray'ed?" Didn't seem to have this issue with 10.3.5
Old 06-22-2013, 12:02 PM
EricWillhelm EricWillhelm is offline
Default Re: 10.3.6 Problem with "Save Copy In"
I think that gets forced ON because of the earlier version's incompatibility with interleaved files...even if you're not using any. Though I see on your screenshot you do have a stereo track or two.
Old 06-22-2013, 12:31 PM
Thanks, Eric!! DERRRR... I should have known that if I'd paid better attention in class.
So, if I go into my edit session and split those stereo files into mono l/r, I should be able to export/'save copy in' without duplicating?
Gonna try it now... Thank again for chiming in!
Old 06-22-2013, 02:07 PM
I THINK it stays greyed out just as a safeguard. If that's the case, yeah, just export it anyway and hand over the session file (and the split stereo files if need be).
Old 06-24-2013, 01:38 PM
Felix Rost Felix Rost is offline
see also here:
http://duc.avid.com/showthread.php?t=317003
http://felixrost.de
Old 06-24-2013, 01:53 PM
gives's Avatar
gives gives is offline
Hope they fix this.. I send stuff to Dub Stages and a lot of them are running PT 8 or something still. Have always export selected tracks as a new Protools session for them and I have sometimes a bit of stereo music Interleaved. I usually export them onto two track though. Hope they fix this one.
another reason to not be on 10.3.6 yet.. since I am not running HDX for at least another update or two.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 06-24-2013, 01:59 PM
I'm confused as to what needs to be fixed. If there are interleaved files, then they indeed need to be split for use in older versions. If there aren't any, you just upload the session file sans audio files, and trash the dupe audio files.
Old 06-24-2013, 02:00 PM
gives's Avatar
I'm confused as to what needs to be fixed. If there are interleaved files, then they indeed need to be split for use in older versions. If there aren't any, you just upload the session file sans audio files, and trash the dupes.
That's what I think, but it seems to be a problem here..
Old 06-24-2013, 05:40 PM
Chief Technician Chief Technician is offline
Lightbulb Re: 10.3.6 Problem with "Save Copy In"
If you think you found a bug, please log it at protools.ideascale.com.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
PT10 : Volume automation disabled after "Save copy In" brenny Pro Tools 10 2 06-18-2015 02:33 AM
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 12:25 PM
Big Problem using "Save Copy In" ProdGawd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2010 04:01 PM
"save session copy in" audio file name shortening simonchase Pro Tools TDM Systems (Mac) 2 05-10-2002 04:39 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
