Old 01-03-2022, 11:06 PM
WildHoney WildHoney is offline
Default Atmos -- why are my objects playing out of time?
Working on an Atmos template where I have audio routed through a mix bus aux and then to a 7.1.4 array of objects. I have another template where that mix bus runs to the Bed instead of objects. But in either template, when I take a track and toggle it to Object mode, it plays AHEAD of the rest of the audio. I'm guessing this has something to do with bussing and delay compensation, but i can't figure it out. Are objects NOT compensated by ADC?
Old 01-04-2022, 01:58 AM
BScout BScout is offline
Default Re: Atmos -- why are my objects playing out of time?
Are you using Dolby Audio Bridge or Dolby Send/Return?
Send/Return are not compensated. You have to manually compensate those channels.
Old 01-04-2022, 10:06 AM
Yep. Using Dolby Audio Bridge on the same machine as protools.
Old 01-12-2022, 05:12 AM
stefanboman stefanboman is offline
Also noticed this.
Very strange that this is not a bigger deal to people.
See my post
https://duc.avid.com/showthread.php?t=418536
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-12-2022, 05:13 AM
For me its only in real time bounce.
Offline is working for me.
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-12-2022, 08:47 AM
Wow, I wasn't aware you could do an offline bounce through the DAPS.
Or am I misunderstanding your question?
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 01-12-2022, 08:57 AM
its2loud its2loud is offline
Frank.
You can't do an Offline Bounce through DAPS. Since Pro Tools 2020.11 you can do an offline or online bounce of an ADM.wav file as long as the Dolby Renderer is running and linked to Pro Tools.
You can do Offline Re-Renders from DAPS however.
Old 01-12-2022, 09:31 AM
Ah, right.
Old 01-12-2022, 09:37 AM
Originally Posted by stefanboman View Post
Also noticed this.
See my post
Same. I've been running delay compensation past the max on the mix bus for years, but with Atmos I've got to come up with a new plugin chain for the mix bus. Ozone bass control module in Atmos is pretty much a non-starter until we get more delay compensation time as far as I can see.
Old 01-12-2022, 10:12 AM
Ah, yes sorry forgot to mention I bounce directly in Pro tools.
But I’m well within the boundaries of the delay compensation limits and there’s still no compensation for the timing difference between bed and objects in real time bounce.
Done proper tests and 100% NO compensation in real time.
Offline is fine.
I guess I must be somewhat unique to try to mix Atmos on a hybrid setup 😂
And of course hardware inserts doesn’t work in offline…
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
HTML code is On
Dolby Atmos mapping to objects troubles kinomatic Post - Surround - Video 2 06-05-2019 01:19 AM
Pauses while playing 1st time only climber Pro Tools 12 5 01-30-2017 08:06 PM
Clip Groups to save time in TV Series for ATMOS? Soundburst Post - Surround - Video 4 06-19-2013 08:57 AM
Playing out of time tboyee Tips & Tricks 2 12-02-2005 03:40 PM
Move objects with time lock?? Robby Hamilton Pro Tools TDM Systems (Mac) 1 08-24-2002 06:56 PM
