Old 03-31-2017, 05:41 AM
danjlambert danjlambert is offline
Default Play button flashes as stops (not external sync, not wait for midi)
Hi all
I've seen a few posts regarding this so I already presume my issue won't be fixed, but worth a shot, as I think I've nailed down how the issue comes about.
Pro Tools 12.6, Mac Pro running El Capitan. Focusrite Clarett 8 Pre X.
More often than not, Pro Tools will end up with the 'play button flashing' symptom - which means I am unable to play a session. Not only this, when this happens, when trying to close the session, pro tools crashes every time without fail.
It's not on wait for note, it's not on external sync, I have trashes preferences, I have shut down/restart etc etc etc etc....
HOWEVER! I've noticed this happens when using Chrome. I do a lot of voice over sessions, and quite often I am instructed to find a video/song (for example) to play for mood. Once I open Chrome (note it doesn't happen every time), and play a song through AudioNetwork for example, or even youtube, this is when Pro Tools dies.
It appears Chrome seems to disable the playback engine is it boots up. Or similar.
Has anyone experienced this, if so, is there a fix?
Changing buffer or re opening session causes a crash.
Thanks!
Old 03-31-2017, 08:05 AM
john1192 john1192 is offline
Default Re: Play button flashes as stops (not external sync, not wait for midi)
Originally Posted by danjlambert View Post
Hi all
Thanks!
been trying Hard to Reproduce here with no luck ... do you have a session that does this consistently for you ??? if so can you post it somewhere - i will download and test for you .... john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-31-2017, 09:08 AM
Cheers John
It's not session dependant, and it's happened just now as I come onto the forums!
Playback does not work and I know when I close the session, it'll crash and I'll have to force quit..........
Old 03-31-2017, 09:10 AM
Cheers John
yep... completely crashed......
Old 03-31-2017, 09:17 AM
melloj melloj is offline
Yep I get this happening. Only cure is restarting Pro Tools. I get this along side other bugs such as 9173. I'm on PC but use Firefox. Not seen a pattern seems to be random.
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 04-16-2020 03:03 PM
Play button flashes hmnyusa Pro Tools 12 11 10-31-2016 01:54 AM
play flashes then stops. session wont play. hellbert Windows 21 03-31-2011 10:49 PM
Play button flashes before starting jonathans9 Pro Tools TDM Systems (Mac) 5 04-19-2008 02:09 PM
Dead Talkback on PC - button now flashes when held audiomark ProControl, Control|24, Command|8 2 12-14-2007 01:17 PM
