Lost files and can't record.
Hi, I've recently begun using Protools and have so far completed two projects. However, when I opened Protools ready to re-record a bass line last Friday I discovered that all my audio files had been lost (luckily, I had previously bounced the tracks down to mp3).
This is what happened next so I hope someone can provide a solution, as for the moment, my investment in Protools is useless. 1. A 'regenerate files' window appeared. I clicked this and some files regenerated, but two were still missing. I tried opening other versions of the same project, only to discover that in some of them, [U]all[U] the files were missing, 2. I went back to the original project and decided to re-record the bass line over the greyed-out missing track. A window appeared saying 'no record volumes designated'.. I didn't know what this meant so I Googled it. The suggestion was to " “Check Disk Allocation and be sure that all tracks are pointing to the correct drive”. I don't know what this means. I checked disk allocation and all the tracks were there but when I clicked on them all that appeared was a notice saying "In input 1 (mono). 3. I went back to my tracks again and noticed that in the I/O dropdowns, instead of Input 1, it now said 'In input 1 (mono) and the same message about no record volumes designated. On Friday, I tried uninstalling and re-installing several times and even deleted Protools from my computed and re-downloaded. Then I gave up. Today, I opened my Protools files to try again and the same issues arose. What's more I have now lost every single audio file on every version of the main projects I have worked on over the past month. I hope someone can help. As I said above, for the moment my investment in Protools is useless and all the work I had done on the album I was recording has disappeared. I'm not happy. |
Re: Lost files and can't record.
Hi. Welcome to the community.
You must provide as much information as you can, before anyone can help you. Start here: Help Us Help You |
When you say "Projects", are you talking about a "Session"(which lives on your computer) or a "Project"(which lives in the cloud)? If it is indeed a project, maybe its an internet issue or maybe a login issue?
Signal Lost intermittently while In Record. | stringbassist | macOS | 3 | 01-30-2019 11:32 AM |
Pro Tools 12.6 not copying audio files on import! = Lost files | DJ Hellfire | Avid Pro Mixing General Discussion | 2 | 10-07-2016 07:27 PM |
lost ptx files | stics1976 | Pro Tools 10 | 5 | 02-24-2016 03:49 PM |
Why do i lost files? | kalony | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-13-2008 09:21 AM |
Lost files and renaming files | GoneIndie | Pro Tools TDM Systems (Mac) | 2 | 01-13-2005 07:08 PM |
