Aggregate Device Editor
I'm trying to set up my MBox as an Aggregate Device in Audio & Midi Setup, but it doesn't seem to be recognised. It appears in the Audio & Midi Setup and I can select it as my Default Input and Output, but for some reason not as the System Output. I have tried doing the same thing with an M-Audio Fast Track Pro and it seems to work ok. I'm not sure if its relevant or not but in Sound, System Preferences, the Fast Track Pro is labelled as USB under Port but the MBox has nothing under Port although it is USB and works under normal circumstances. I'm running Pro Tools 6.9.2 with OS X Version 10.4.11 on a 1GB 700MHz PPC G4 iMac Thanks in advance. |
Aggregate device help please... | shotgunndunn | macOS | 1 | 01-30-2012 10:52 AM |
Why can I only see one aggregate device in PT9 | multivir | macOS | 1 | 02-13-2011 07:58 AM |
Aggregate device trouble Snow Lep! Tascam US122 won't aggregate? | crizdee | Pro Tools 9 | 3 | 12-02-2010 03:17 PM |
Mbox not showing in Aggregate Device Editor | bluerockgod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-01-2006 07:05 PM |
Mbox not showing in Aggregate Device Editor | bluerockgod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-29-2006 01:11 AM |
