Re: Looping Info needed
I've seen a bunch of other Looping questions - tried a few things but none that seem to nail it. I loved Elastic audio - got the loop to line up perfectly - or so I thought.
I'm going back to the original audio and try Beat Detective instead. fer now. |
I ended up cutting and pasting the warped audio after stretching/syncing it to a grid - 6 minutes in perfect time - but it didn't like my handmade crossfade's; I guess warped audio acts differently? (i'm grasping) but I can't hear the forest 'for the scissors anyway - and it sounds fine after adding everything else - and most importantly it keeps time!
and no, this may not be the way it 'should' be done - but we give thanks and move on. |
Lets back up a couple of steps, when you select the region and right-click and select EA Properties did you conform the length of the region to four or eight bars?
Aaron Mulqueen - 001 HD Native |
So, when I select Region -then Loop - a box appears: # of loops/ Loop length/ Loop until end etc/enable crossfade w/ settings. The loop is exactly 4/0 ; in Bars/Beats mode. should be a slam dunk. yet it goes off on the very first loop when i set '# of times' to 2 -just to check it. |
Option+5 - Elastic Properties. Source Length (Tick-Based Track) did that display an exact four or eight bar length?
#16
Not from around these parts, are you?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
#17
too late for a quick reply; thanks for stickin w/ me but if ya give up on this thread, i understand. I been too busy tracking the song w/ the aforementioned 'handmade' pasting that took all of 3 minutes to make, albeit w/ no crossfades that worked. Still, it baffles me & would rather have it done right and learn somethin. So..getting into Elastic properties did not reveal the regions length! only: TCE factor, event,input, etc. In the region area, it shows a little clock icon, and the file name.
#18
I suggest you spend a little time understanding Elastic Audio and it's benefits. DTV has some great videos covering this subject.
003 Rack info needed | mcgibbon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2009 06:11 AM |
Drum info needed | jvo11 | Pro Tools TDM Systems (Win) | 1 | 09-09-2005 08:26 AM |
DVD specifications, info needed. | gerax | Post - Surround - Video | 7 | 05-27-2004 10:16 AM |
Digitranslator Info Needed ASAP | ScottMan | Pro Tools TDM Systems (Mac) | 5 | 04-15-2003 10:40 PM |
Expansion chassis info needed | Digidaw | Pro Tools TDM Systems (Mac) | 3 | 01-17-2001 04:59 AM |
