Please how to obtain statistics (peak, loudness, etc.) of a clip in Pro Tools?
Please how to obtain statistics (peak, loudness, etc.) of a clip in Pro Tools? Offline. Cubase-Nuendo, this is very easy. One click on clip and request the measure. In one second we have the complete statistics. I have lots of plug-ins, some of them measuring the loudness, but in real time. I also Lm1n TC, but even "audio suite" measures only loudness and not ... 192 kHz ...
Re: Please how to obtain statistics (peak, loudness, etc.) of a clip in Pro Tools?
surprised no one's answered this;
audio suite gain will give you peak and rms... e
ihatetyping |
The following audio gain, in fact, can help, I do not remember. It is basic, but it definitely helps out. For information, look the same function in Cubase (here in French and only text) Title;Statistiques - "finale" Date;jeudi 25 février 2016 Loudness_Value;-25.80 LUFS Loudness_Range;17.95 LU Max_True_Peak_Level;-11.19 dBTP Max_Momentary_Loudness;-18.03 LUFS Max_Short_Term_Loudness;-24.03 LUFS Sample Rate;96.000 kHz Average RMS (AES-17) Gauche;-40.28 dB Average RMS (AES-17) Droite;-39.99 dB Max. RMS Gauche;-20.11 dB Max. RMS Droite;-19.73 dB Max. RMS;-19.73 dB Min. Sample Value Gauche;-11.79 dB Min. Sample Value Droite;-11.19 dB Max. Sample Value Gauche;-13.28 dB Max. Sample Value Droite;-13.69 dB Peak Amplitude Gauche;-11.79 dB Peak Amplitude Droite;-11.19 dB True Peak Gauche;-11.79 dB True Peak Droite;-11.19 dB DC Offset Gauche;-oo dB DC Offset Droite;-oo dB Resolution Gauche;32 Bit Resolution Droite;32 Bit Estimated Pitch Gauche;1305.9Hz/Mi5 Estimated Pitch Droite;1288.1Hz/Mi5
And the Avid Pro Limiter comes with an offline LUFS analyzer.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thank you. Really expensive for non-hd.
Really nice to have however.... It would be nice to have avid include such info, standard of course
Getting these statistics is crucial for a weekly summer project that we do for the same client every year. We recently switched over to Pro Tools and we didn't imagine we wouldn't be able to do this in Pro Tools. We've been using pro tools for a little while now, but we didn't realize this feature was missing until summer rolled around. It's amazing how you don't realize how important a small simple feature can be until you don't have it anymore! We had to go back to our old set up for this project.
There is a free way of getting these statistics if you don't have access to any other expensive DAWs or audio analysis software, but unfortunately it is outside of Pro Tools. I hope this is helpful if other people people are in such a situation. Audacity can give you amplitude statistics if you install the ACX Check nyquist plugin. In Audacity, select the audio you want to analyze, then on the menu bar select Analyze>ACX Check. The major disadvantage of this is if you are making constant edits to the audio file(s) in Pro Tools, you have to swap the files back and forth between programs. And if you want to playback in Audacity, I believe you have to close Pro Tools first because Pro Tools takes exclusive control of your audio drivers. So it works, but depending on what your needs are this can be a major pain in the *** solution. The only way I have thought of getting amplitude statistics within pro tools is if you have have iZotope Rx v4 or later. You can use the RX Connect plugin, which will allow you to use the "waveform statistics" feature in the RX standalone application. While this is not truly "inside" pro tools, it allows you to use Pro tools I/O. I love iZotope RX, but unfortunately at home I only have access to RX2 at home, which does not have the "waveform statistics" feature. So I haven't tried using RX Connect, but in theory it should work and only minimally disrupt your workflow. There may be other expensive 3rd party options as well. I have spent many frustrating hours trying to find a free or cheap plugin to allow pro tools to do this simple task, before I gave up and looked outside of pro tools. I found a bunch of free/cheap RTAs aax 64bit plugins that can give amplitude statistics in real time, but none which have a feature that can give statistics based on a selection not in real time. And I'm not going to buy anything pricey just to be able to do this. If anybody knows of a plugin that can do this or a in the box Pro Tools solution, please let us know! I'll even take any VST plugin suggestions, which I can host in Reaper and use its ReWire plugin to get into Pro Tools. Not knocking Audacity, but it is a little embarrassing to have to go to audacity to do something so simple because Pro Tools is incapable of doing this. Especially because most of Avid's competitors can already do this as a standard feature. I remember be able to do this in Adobe Audition v1.5, which was released in 2004!
Pro Tools 11 Windows 10 x64 Desktop PC with Intel i7-3770 CPU, 18GB RAM |
Using the plug-in "gain" in AudioSuite (Analyze). It is not complete, as in Cubase-Nuendo, but it's good for the peaks and RMS.
One that I didn't mention originally, is audioleq
whose free version can do Graph Peak Levels, Unweighted / A-Weighted L+R Leq in a couple of seconds as well as batch processing. there is also a version that does Peak, RMS Unweighted / A-Weighted Histogram and 2-Channel LKFS Loudness (RLB/R2LB), 44.1 to 384 kHz… e
ihatetyping |
How does one obtain Pro Tools HD? | ianbee | macOS | 2 | 10-28-2013 06:56 PM |
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 | hotgravy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2012 10:49 AM |
CALM Acts Audio Loudness, Average Loudness, Program Loudness levels... help needed | qr2r | Post - Surround - Video | 12 | 11-10-2011 01:41 AM |
Q: If I recently purchased a Pro Tools LE software upgrade—how do I obtain Pro Tools | dmm | Pro Tools 9 | 0 | 11-12-2010 10:14 AM |
Peak/Clip trouble | Kdose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-17-2010 12:30 AM |
