Old 05-15-2021, 06:33 AM
cannond cannond is offline
Default Drum Bus Fader recoiling to the bottom when trying to increase sound
Hi folks,
I hope someone can help me with this.
I have just come over from Mixcraft to Pro Tools. I sent over all my stems and have them loaded into Pro Tools. They are working fine. I have sent up busses for the various groups of instruments. I started on the drums I changed the output to Bus 1-2 Stereo. They are working, the only thing is when I try and use the fader, it just returns to the bottom and there is no sound. It just recoils back to the bottom. Can anyone help, please?
Old 05-15-2021, 07:06 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Drum Bus Fader recoiling to the bottom when trying to increase sound
In general it sounds like automation points.
Read up there and see.
Old 05-15-2021, 07:18 AM
Hi DetroitT,
Yes increasing the db on automation helped, it's working now, is there any way to get rid of that on the drum bus?
Old 05-15-2021, 08:27 AM
DetroitT's Avatar
Select volume view for the track, select-all. Delete.
Glyn Johns drum method for big drum sound within PT? Eminence Front Tips & Tricks 15 04-04-2015 05:36 AM
C/24 fader banks slam to bottom ? jackp ICON & C|24 0 04-07-2011 07:41 AM
Command 8 fader 1 sticks a bit at the bottom. lkingston ProControl, Control|24, Command|8 0 05-13-2010 06:05 AM
Increase - Decrease Increase H/W Buffers 6string 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-22-2008 05:37 PM
Buffer problems - Increase-Decrease-Increase 6string 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2005 10:01 AM
