7.4 not remembering my window positions
I have my session windows spread across 2 monitors and since 7.4 it no longer remembers my window positions, but instead it defaults to just one monitor!! so every time i load a new session i have to re set my windows Chris
Re: 7.4 not remembering my window positions
hmmmmm maybe they forgot to test that part
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
My 7.4 remember windows positions, works fine!!
Chris
Hello, I have 3
Two Apple 23" in the system VGA and a 8" VGA touch panel in a second PCI VGA. I just check only with the two Apple displays and works fine. Bye |
Crizdee - what's your computer configuration? Which video card? Which monitors?
It's working fine here...! |
G5 2G Dual PPC. GeForce FX5200 graphics. 2x LG flatron L1910s. The PT windoes always default to the secondary monitor!! I've never been able to use windows configurations either? Chris
BUMP
Anyone else noticing anything along these lines? My QT window is forgetting the location of it self on the 2nd monitor, every time I open the session again it's in the middle of the 1st monitor screen. |
Can you tell me exactly how you have the monitors connected (which one is connected to each port on your graphics card), if you're using any adapters and how you have the windows configured in the Displays control panel?
MIX/ EDIT Window Positions anomoly | Elton Hyland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-02-2007 02:38 PM |
Screen/window positions - should this work? | Trailerman | Pro Tools TDM Systems (Win) | 5 | 02-24-2006 10:05 AM |
PTLE Window positions,T-Racks settings not saving | Cruel Hoax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-19-2004 09:39 AM |
Remembering window positions for dual monitors. | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-23-2002 11:54 AM |
Saving window positions | sburgess | Digidesign Hardware & Software | 0 | 04-25-2001 09:45 AM |
