Old 12-26-2004, 01:06 PM
romkey romkey is offline
Default Stumped over setting track input on a digi 002
Trying to get my new 002 to work and can't get the mics plugged into third or fourth inputs to pick up signal. I know it's not the cable because if I swap them to the first or second input they work fine. All the manual says is "set track input (mic/line 1-4)." I suspect the control surface is supposed to detect the additional mics in 1-4, notify the software and allow me to assign them to whichever tracks -- except the only choice it's giving me is 1-2. I've reinstalled the software and spent two days trying to figure out what dumb thing I'm doing. I give up. Any suggestions? Mac OSX environment. New board. New software (thought 6.4, which is all Sweetwater was shipping when I ordered). Thanks. -- Mike
[email protected]
Old 12-26-2004, 01:13 PM
KingFish KingFish is offline
Default Re: Stumped over setting track input on a digi 002
Load your session, under Setups, go to I/O Setup
Click on EACH tab at the top, one at a time... Input, Ouput, Insert, and Bus.
WHILE you're on each tab, hit the "default" button near the bottom, and move to the next tab.
When you have done all 4 click OK.
Sounds like you are opening a session, that was created on an M-BOX or AMIII, regardless, you need to set your I/O path to the default of the 002
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 12-26-2004, 01:20 PM
THANK YOU!!!!! With joyous gratitude from a former Mbox user (great guess!), Mike
Old 12-26-2004, 01:33 PM
Wasn't really "a Guess" glad you're up and running.
David
- MacStudio M1
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? awhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2010 08:50 AM
Aux Input Default Setting wyman Pro Tools TDM Systems (Mac) 3 02-17-2007 04:30 PM
Complete set up of digi 002... STUMPED Infamous24x7 General Discussion 4 01-20-2006 08:21 PM
No sound from keyboard MIDI controller to Digi even after setting up Aux track Honkey Kong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-23-2002 10:42 PM
Seeking input on setting up the Digi 001w/LE5.1 for Broadcast Production Juris H. Josts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-24-2001 12:57 AM
