Old 05-04-2022, 08:58 AM
quadraphonics quadraphonics is offline
Default Cannot Bounce to Disk because of...
I am getting repeated 'Cannot Bounce to Disk due to Vector' or 'Cannot Bounce to disk due to std:exception' errors.
Quitting Pro Tool and relaunching the session solves this issue.
These happen in multiple rooms across different session and storage mediums (local and SAN).
What causes this and how can I solve this issue?
We are on 10.13.6 and PTU 2020.12.
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 05-04-2022, 12:27 PM
reichman's Avatar
reichman reichman is online now
Default Re: Cannot Bounce to Disk because of...
Your setup is more complex than ours, but whenever I've seen errors like that, trashing:
MiscSettings
Workspace.wksp
Workspace.wksp-shm
Workspace.wksp-wal
in Users/Shared/Pro Tools usually clears it up. You've probably already done this, just checking...
Nathaniel Reichman
Producer/Re-recording Mixer
Dubway Studios | Rhumba
14 East 4th Street, Suite #602 | New York City
Old 05-05-2022, 02:24 PM
Thank you. I will give that a shot.
Randall
MiscSettings
Workspace.wksp
Workspace.wksp-shm
Workspace.wksp-wal
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 05-06-2022, 12:14 PM
For what it is worth, deleting these files had no impact on the frequency of the issue.
Randall
MiscSettings
Workspace.wksp
Workspace.wksp-shm
Workspace.wksp-wal
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 05-11-2022, 03:45 PM
Avid? I would like some type of answer as to what this error means and what causes it.
Thank you,
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 05-11-2022, 10:58 PM
jeffro's Avatar
jeffro jeffro is offline
Not a common error, and I've been unable to repro (though I'm on macOS 10.15.7 at the moment). I could only find one similar report which was from years ago (v12.3) when using multiple duplicate outputs in the Bounce dialog.
Has it always done this or did the start of it coincide with any other changes?
I'd recommend stepping through the optimizations and troubleshooting at https://avid.secure.force.com/pkb/ar...Optimize-10-13 then start a support case and report back with the case #.
Old 05-11-2022, 11:25 PM
Getting low level C++ stdlib runtime errors like "std::exception" (and I'll expect the other is std::vector) means something is badly messed up. And the best way to badly mess up low level stuff in Pro Tools is... plugin issues. Which could also explain why this is seen in all rooms if you've installed the same plugins on systems in those rooms. So that is where I'd start troubleshooting.
So try basic standard troubleshooting: Try just trashing prefs, that not fix issues then move all .aaxplugin files out of the plugin folder, trash prefs and test with only the standard Pro Tools plugins installed which will automatically be put back when you start Pro Tools.
Old 05-12-2022, 09:36 AM
This has been an issue with 2020.12, which we are stuck on for video output reasons.
I believe it happened a bit on the version we used prior, but not nearly as much.
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 05-12-2022, 09:37 AM
Darryl,
We have tried trashing preferences.
I will try moving all of the installed plugins to the unused folder and trying again.
Thanks,
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 05-12-2022, 11:26 PM
fork-media fork-media is offline
i get these types of message quite often. But usually for bounces with video.. usually goes away if I quite and relaunch PT.
if it doesnt then I use the Peter Gates PT pref app and delete then restore form a backup prefs..
i7 6 core mac mini running monterey 12.3.1 - 32Gig RAM SSD
Focusrite Saffire PRO 40
Ultimate 202112 / HD Avid MC Mix / MC Control
HTML code is On
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? js_nyc Pro Tools 12 6 04-21-2016 04:37 PM
Bounce to Disk: Bounce to disk length is longer than my track on my time dijitalhorse Pro Tools M-Powered (Mac) 1 02-23-2016 07:27 AM
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 01:41 PM
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 08:16 PM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 10:07 AM
